FML this happened when I want to debadge
ElmoHongZito
Doral, Florida
2018 Civic Type R
Was about to debadge the civic badge from the trunk. I hit it with a heat gun for a few seconds and noticed that the letters were already a little lose to the touch. Mind you I live in Miami so the heat from outside may have already been sufficient. I get my nylon fish line behind the C and it peeled off very easily leaving the adhesive behind. Only problem is that some of the white paint came off as well (see picture below). I only witnessed it after the C came off so I don’t know if the heat caused it or not. I am so pissed. I stuck the C right back on. I regret using the heat gun because that may have been the culprit.
Thoughts on what happened here? Do you think I can debadge everything (without heat gun) and somehow touch up this area well? I’m scared I already started it and it will continue to peel.
I was so freakin pissed that I forgot all about the heatgun on my lap and accidentally touched the tip with my forearm leaving a nasty burn. Right now I can care less about the burn.
Honda Civic 10th gen FML this happened when I want to debadge 3A3C19BB-9FB1-4567-83C0-0A41188613A9
Holtz
NY
2017 Honda Civic Hatchback Sport 6MT
Let me help you so you don't freak out. Here are a few things you can do.
Continue with the fishing line / floss and remove everything.
Grab some goo gone and take off what's left of the adhesive (let soak for a few mins) rinse and repeat until all gone.
Take to a body shop to patch up what you messed up for a few hundred dollars if you care about pristine paint work.
Grab a touch up oem honda paint pen and touch up the paint + clear coat - everything comes together in pen.
OR - don't actually commit to debadging - go on ebay and buy "civic" again.
rebadge everything - clean up area + prep it with alcohol and just slightly move your civic letters over a little to cover up your messed up paint work. Ideally you could use a touch up pen here before reapplying the letters again.
ElmoHongZito
Doral, Florida
2018 Civic Type R
Thanks for responding. When I put back the C it covered up the messed up paint work. I still want to debadge specially now that I feel like a failure after butchering it on the first try. Guess I will try the touch up solution and taking to a body shop will be last resort.
I saw so many youtube videos on how to debadge and not one expressed any warnings about how the heat gun could losen the paint like that in a few seconds. Mind you some of them used hair dryers because they don’t own a heat gun.
Wow, that's messed up. No way debadging should cause the paint to peel off like that. How hot was that heat gun???
KeepItLow
Sydney, Australia
Car
I always debadge my car using a hair dryer as I think the heat is easier to control, feels like to me your heat gun way too hot..
Good thing is that you can just buy that garnish piece from factory painted as well and replace it, which is what I would do!
https://www.hondapartsnetwork.com/oem-parts/honda-garnish-assembly-rear-nh0-74890tghe01ze?c=Zz1ib2R5LWFpci1jb25kaXRpb25pbmcmcz10YWlsZ2F0ZS10eXBlLXImbD04Jm49QXNzZW1ibGllcyBQYWdlJmE9aG9uZGEmbz1jaXZpYy01LWRvb3ImeT0yMDE4JnQ9dHlwZS1yLXRvdXJpbmcmZT02LXNwZWVkLW1hbnVhbA==
Civics4Ever
Rally Red EXT
Gene
Illinois
Waaaaay too hot. Even looks like the paint is burnt.
98-0425
Nick
Las Vegas
18 Civic Type-R #12307, 98 Integra Type-R #0425, 07 Pilot EX-L, 17 Pilot Elite
I used a hair dryer, floss, and goo gone. No problems here.
wayoutwest
Orange County, CA
R-19644
Same here - hair dryer, dental floss, and i slide tape under the edges of the letter so nothing gets scratched while i am wiggling the floss through. Done 4-5 cars this way and have never had any issues.
Oh, and i use the 3M citrus based adhesive remover. It is like $20 for a bottle on amazon, but its way less harsh, and i'm sure the bottle will last me an entire lifetime as you really don't use much at all. I actually just spray it on a microfiber towel and lightly go over the remaining adhesive until it is gone. Then apply a coat of wax after. Takes longer but has always worked for me. Hope you are able to repair it!
Noize
Under the radar
2018 Civic Type R, 2017 GTI SE DSG
I never ever use a heat gun or hairdryer. I used floss and then Goo Gone, it was even a cool day. Easy as pie. Sorry for your troubles.
Honda Civic 10th gen FML this happened when I want to debadge 3D5BF3B0-D647-42B3-AADA-E2BE49718438
Morning Mahogany
Albuquerque, NM.
2018 Type-R
:doh:
Re-badge > De-badge
I’ll post my black chrome replacement when I find time. It re-balances the rear with the type r emblem already in place.
jasonjm
Jason
Pennsylvania
Type-R
Ditto hair dryer used here as well. On low.
This part is plastic, a heat gun is too much.
keiothic
YoK
DFW
'19 FK8 CW #22485
Had a similar situation a few months ago when removing my dealer's badge. Ridiculous to think how much they press against the paint, leaving an indent and a chip. As I was trying to clean it to fill in the paint chip, I just made it bigger because it's plastic. Doing paint correction while stressed is definitely not a good combination. After contemplating back and forth on whether to get the $30 Langka blob eliminator, I went for it and fill it in gently/patiently, as best as I could, with calmer state of mind and expectation that it can can never look 100%, but at least from a far, it tells a happier story.
Honda Civic 10th gen FML this happened when I want to debadge upload_2019-4-16_20-43-51
TL;DR: Langka blob eliminator (and Honda paint touch-up pen obviously)
Mick the Quick
Mick
Southeast MA
2018 PMM Civic Type R (R-08508)
Wow, I have never seen anything like that. The only thing I could think of is that you had the heat gun in the high setting, had it too close to the surface, and didn’t move the gun around. But even that is highly unlikely. Perhaps it was a pre-existing damage that you hadn’t seen?
Roadcone
Kyle
Upstate, SC
'14 FR-S + '19 CTR
:doh:
Re-badge > De-badge
do you have a black chrome red h badge too? I'd love to swap everything to black chrome but only if i can get the red H's too
