Dm0785
- Darwin
- Mar 10, 2020
- 4
- 50
- 121
- GA
- 2018 Honda Civic SI
[Update]
First time owner of an fk8…kinda. Came across a good deal for a flood damaged type-r that someone had already started to repair. Normally, I’d stay away from flood damaged vehicles, but I felt a strong need to try and bring this car back to life. Bad idea? The jury is still out on that one….
Mechanically the car runs and drives. Electronically though there’s some things that need replacing/ going through.
Anyways, I’m posting here in the hopes someone has more knowledge or experience than me with some of these codes. Or can at the very least point me in the right direction. I hope that our collective minds can help get this type-R back on the road.
Thanks in advance!
Engine Permanent Codes (2)
Engine - Temporary Codes (2)
Door Locks - All Body Electrical Codes (4)
Antilock brakes - Permanent Codes (2)
Airbag (SRS) - Permanent Codes (1)
Active Damper System/ Adaptive Damper System - Permanent Codes (1)
Thanks in advance!
- P16E3: PGM- FI Battery Sensor LIN Communication Error
- P2422: EVAP CVS Stuck Closed
- B2983: A problem in the recirculation control linkage, door, or motor
- B1225: an open in the in-car temperature sensor circuit
- B123F: automatic lighting control unit/ sunlight sensor error
- B12C5: engine start/ stop switch failure
- C003338: Magnetic Encoder (Right Front) Failure (Pulse Missing)
- C111013: Left Rear Electronic Parking Brake Actuator Circuit Open
- B0090-87: No Signal From The Left Front Impact Sensor
- C1644-14: Left Front Stroke Sensor Lower Limit Abnormality
