Amedina801
- Adam
- Sep 15, 2019
- 4
- 12
- 2
- Utah
- 2018 Honda Civic Si 1.5T
What do you
Agreed.Beware of misinformation, it will not tear up your injectors- research online- forum people are biased one way or the other.
I have it, 37% ethanol, car runs great
The main difference between the stock turbo and a larger one in this case is how soon boost pressure is built. A good tuner can adjust the tune as needed to avoid the low RPM / high torque risk of engine damage you are referring to. So yes, be careful if you have the factory turbo, but a good tune by a trusted and experienced tuner is a great place to start with any build. This is not a personal message directed to xjoshuax89, just my thoughts on the subject.Being on e85 myself and pretty heavily modified I always give a word of caution/warning to those wanting/contemplating going e85.
Stock turbo e85, I would be wary. We are beginning to see more and more issues of blown motors due to bent rods, piston issues, and head gasket issues with the additional force going e85 will put on your motor. I would recommend it if you are interested in more power but be advised that e85 puts more stress than a simple ecu ktuner or hondata upgrade. Be prepared in the future to make upgrades and replacements as failures/issues can be more prominent.
Definitely true! I should have stated my point a bit more clearly. Thanks for the catch!The main difference between the stock turbo and a larger one in this case is how soon boost pressure is built. A good tuner can adjust the tune as needed to avoid the low RPM / high torque risk of engine damage you are referring to. So yes, be careful if you have the factory turbo, but a good tune by a trusted and experienced tuner is a great place to start with any build. This is not a personal message directed to xjoshuax89, just my thoughts on the subject.
