Flashpro upload issue while custom tuning
Hondata
Hondata
Torrance California
www.hondata.com
93 Integra, 06 Si, 12 Si, 17 Si, 19 Si, 18 FK8, 18 Accord 2.0T
I replied to your support request before finding this thread. Our next software release will remove the 41F limits. In the meantime reflash after the vehicle is warmed up, or allow the vehicle to warm up so IAT and ECT are both over 41F and then power cycle the ignition.
19typer
Kevin
NY
2019 Civic Type R
yes, I just got it. Thank you Do you have an eta on when it will be available?
19typer
Kevin
NY
2019 Civic Type R
sounds good
jasonjm
Jason
Pennsylvania
Type-R
We figured it out. You have to flash when the coolant and intake temperatures are above 41F. You'll need to bring it into a garage or something. They're working on a patch now. It's a behavior built in from the factory - nothing to do with Hondata.
I’ve flashed when the car was bone cold and 20 degrees outside. In my garage (which is not properly insulted) prob was below 41. Never had a problem with version released last year Jan. Maybe even earlier.
Then again maybe it was on the line. You sure this always existed? With older ECUs?
Hondata
Hondata
Torrance California
www.hondata.com
We don't make random changes to versions. All the evidence points to the throttle re-learn minimum temperature being the problem.
- when this occurs I can taken calibrations from affected vehicles and uploaded 20+ times into another vehicle without a problem
- there is an error code which specifically tells us the problem is that the idle re-learn is not being performed
- Honda documentation lists that the re-learn will not be performed if the IAT or ECT is below 40F
- inspection of the code confirms the same behavior
- workarounds work eg reflashing the same calibration when the vehicle is warmer
- only people is cold climates in winter get this problem
kefi
oh shit waddup its dat boi
Central Florida
fk8.clinic
2018 Type R
This was not Hondata. Besides all the reasons above, I have found posts from years ago where it affected people on KTuner too.
19typer
Kevin
NY
2019 Civic Type R
1sikvic
Civic type r
Any update on the issues with flash pro. Seem many still having issues
19typer
Kevin
NY
2019 Civic Type R
It seems to work fine now, haven’t had an issue since they updated
1sikvic
Civic type r
Ok I had a tunner say there was issues still. Just hope it's fixed still waiting on kefi on my situation now.
