Very, very slowly. Pretty much in 5th to get to 45kmHow did you do that? I can’t go above 1800 rpm in any gear. I just drove around the neighborhood side roads.
So basically impossible anywhere besides a military base in Canada amirite ?Very, very slowly. Pretty much in 5th to get to 45km
Besides reflashing over and over, that’s the only other thing we’ve found so far that works.It would take me ten minutes of driving on main roads to get to where I can do that. Is that the only option?
That's the only thing I've had success with. Driving to a dealership cleared the code because it was a longer drive. I've pulled the battery, reset the temp. memory, fingered my throttle body, heated my throttle body, and even killed my battery multiple times from flashing it so many times.Besides reflashing over and over, that’s the only other thing we’ve found so far that works.
Stop and go should be fine as steady is obviously next to impossible, but from the research I've done the permanent CEL is related to emissions and requires very specific requirements to clear the code. I believe the speed needs to be maintained for 10-15 minutes cumulative.Ok, so it has to be steady driving at speed not stop and go? Obviously this is a software issue which wasn’t present two versions ago, should be easy to fix I would think
No, in one drive, not multiple cycles. As in you can reach required speed and slow down multiple times during the same drive, but it must be the same drive. I will try and find the article I was reading and post it here for reference.Ok, I guess I will go out again. Since you said cumulative I can do it multiple times than instead of driving it until it shuts off?
That's not always an option, unfortunately. Thankfully I'm able to get mine working and don't hold you or @kefi liable for any of damages that may occur, but you weren't able to reproduce the error that I was experiencing with my flash, so up until now we assumed it was a problem on my end.If the vehicle is not normal after an upload then don't drive it. Switch it off, unplug the FlashPro from both the vehicle and laptop, switch off the ignition, check the software is up to date then upload again. Don't try to track down errors or do throttle learning or anything like that. And it's not the battery voltage.
If it still does it afterwards then use 'Send Feedback' which will give me the details of the ECU part number, the calibration ID and the last upload log. I'll probably also need the calibration which you can send as part of the feedback process. Datalogs are not useful but sending feedback with the ignition on will give me the error codes.
And unless you are running ethanol, return the ECU to stock if you need to drive it. Don't drive a vehicle when something is obviously wrong.
