- Mitch
- Oct 27, 2015
- 332
- 16,923
- 24,690
- USA
- Website
- www.civicx.com
- 2017 Cosmic Blue EX-L Sedan
- Vehicle Showcase
- 2
Hope this helps anyone new to flashing with the Flashpro who only has a desktop:
1. Install the software on a PC. Plug in the FlashPro, fill out the registration details and register with Hondata.
2. Take the FlashPro to the vehicle, plug it in, switch on the ignition (two presses of the start button) for 5 seconds (but don't start the car). This records the VIN.
3. Take the FlashPro back to the PC, plug it in. Select Online, Lock from the software menu.
4. Select a calibration of your choice from the list, upload to the FlashPro.
5. Go to the vehicle, plug the FlashPro in, switch on the ignition (two presses of the start button). Press the Program button on the FlashPro for over 1 second. If using the secondary slot, hold down the datalog button, then the program button and release the program button first after a second or two.
6. The program light should start to flash after about 15 seconds, then stop flashing once the ECU is programmed (about 5-6 minutes ). You will get weird error codes on the dash. This is normal and they will go away after a while.
7. After programming is done... hold down the start button to turn off ignition. Then start up engine. You are now tuned.
_________
For more detailed help, check out the Flashpro help guide or contact Hondata customer service. I installed using desktop. If you have a laptop this can all be done inside you car.
_________
