Flash Back to Stock include VIN and CVN?
segfault
San Jose, CA
2017 Civic Si, 2006 Mitsubishi Evo
CA Smog has started to check VIN and CVN when they access the ODBII. I know we have the "Return to Factory" flash option, but I was curious if the Factory Tune that gets flashed back includes the correct VIN and CVN. Failure to have those will now get you state ref'd.
My original plan when I first got a KTuner was to flash back the original rom that was made when I first connected. However, that SSD took a crap and I couldn't recover it.
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
We don't alter VIN or CVN data in any way. CVN is a calculation of the data in the ECU, so a return to factory placing you on a factory software will produce the correct CVN for that software version. It's 100% factory software.
All factory softwares that are supported are built in to the software. You can't flash unless we support it already.
segfault
segfault
San Jose, CA
  • #3
Oh, awesome. Thanks for the info! Coming from evo EcuFlash, we flash over EVERYTHING. So I was a little concerned.
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
VIN info should be stored in ECU EEPROM, so it remains unchanged. CVN is a calculated checksum for the ECU software calibration, so a modified flash will not match factory CVN, but a CVN for factory software will always be the same.
Jay Penn
Jay
Bahamas
2016 civic ex-t
I have a question, should the CVN in the ECU be the same as the CVN in the TCM ??
Jay Penn
Jay
Bahamas
2016 civic ex-t
If you have the choice between two versions the description says to match to the closest one listed under KTuner Unit Info. If you didn't do that and flashed the wrong one you'll have a code. Flash the other one.
But i never flashed though, if i flash the car do u think this would be fixed ??
