FK8 Engine oil Filter
NewCivicRs
CIVIC.FK4
Indonesia
Civic 1.5 Turbo RS
Hi, does anyone here ever try FK8 Engine Oil Filter for FK7?
How does it work?
NewCivicRs
NewCivicRs
CIVIC.FK4
Indonesia
Civic 1.5 Turbo RS
K&N shows the same filter numbers for the Type R as the 1.5L, so it should work fine.
Hi, when I held the filter, it weights heavier than FK7's filter, and I can see clearly the filtering cotton, wider than FK7's.
But I was afraid that it is not designed for FK7.
Thanks for the help man. ?
jdm_mike
Acura Canada
20 FK8 CTR & More
FK7/8 oe oil filters are the same. If you're talking about engine filter, they're different
NewCivicRs
NewCivicRs
CIVIC.FK4
Indonesia
Civic 1.5 Turbo RS
Yes, I am talking about Engine Oil Filter. I compare both physically, the FK8's oil filter is heavier, and the filter looks bigger, I can see it clearly.
What do you mean by Engine Filter?
jdm_mike
Acura Canada
20 FK8 CTR & More
The engine air filter? P/n 17220-5AA-A00
Oil filer p/n 15400-PLM-A02 should be the same across all models/trims unless you're going aftermarket
NewCivicRs
NewCivicRs
CIVIC.FK4
Indonesia
Civic 1.5 Turbo RS
No it is not Air Intake Filter.
I am talking about Oil Filter.
I got it now, when dealer shown me both filters, one is written made in japan, which has the same part number as you mentioned.
And another one is cheaper, local made in thailand and/or Indonesia.
The difference is so far, damn.. I would never ever use the cheap, local made anymore.
