juang1985
- Juan
- May 4, 2021
- 1
- 31
- 7
- Los Angels California
- GOLF R MK7
Hello Fellas
Just wanted to get some insight from some of you mechanically oriented specifically suspension oriented people out there.
I wanted to check my alignment to make sure everything was within specs.
Turns out, the caster seems to be a little bit out of spec. 7.2 degrees on each side to be specific.
Is this normal on these type r? according to the alignment software it should be between 7.5-8.5 so I am a little under their minimum range.
My car has under 2k miles so I am assuming this is normal specs ? see picture attached
By the way, tech used database for a 2020 type r Since I am pretty sure the exact same specs as 2021.
thanks in advance fellas
