Austin@Wunderladen Racing
- Austin
- Dec 6, 2021
- 46
- 1,100
- 2,307
- Chicago IL
- Website
- www.wunderladenracing.com
- 2018 FK7
Hey folks, I'm making this thread to introduce myself, my company and our Civic! My name is Austin and our company is Wunderladen Racing, we're a recently established company but between us we've got over 30 years of manufacturing, test and validation with automotive parts. Our main focus is offering parts for the Civic X and Mitsubishi Evo platforms. Many of our products cater towards people who want to use their car on racetracks, autocross or anywhere there is competitive driving events.
I have a firm belief that the Civic X holds a ton of potential as a great candidate for people who want a daily driver that is affordable, good on gas, easy to modify, and able to be very capable around a racetrack. I spent a lot of time evaluating many different vehicle platforms to develop parts for but nothing offered as good of a balance of these characteristics as the 10th gen Civic.
We'll be fielding the car in Gridlife's ClubTR time attack class for the 2022 season. The class is limited to cars with naturally aspirated engines 2.5L and under and boosted engines 1.6L and under. Last year the class was largely dominated by K24 swapped Hondas but we're hoping to show that the 10th gen can hang with these heavily modified, swapped cars without needing to go to equally extreme lengths.
At the moment we've signed up for the following events:
Some of you may recognize the car, it was owned by another member here. It started life as a 2018 FK7 Sport and has been treated to a bunch of Si parts along with some modifications including:
Engine and Drivetrain:
First things first I'm going through the car to take care of some maintenance, seal some leaks, address some concerns like some rubbing that's occurring on the oil cooler lines, and get some bolts in areas where they're wrong or missing.
Most of our starting products will be suspension and brake related. I'm very adamant about improving a chassis through suspension refinements before throwing more power at it. I'll be sharing our new products here as we get prototypes in from our local machine shop, everything we offer is made in the USA ??
One of my initial impressions when I gauged the market was the lack of a proper motorsports big brake kit. All of the factory brembo retrofit setups are far from ideal, and all of them have too much of an impact on brake bias, which can make ABS and VSA not work as well when they activate. The kit we're developing uses AP Racing calipers, for those not aware AP produces some of the most capable brake calipers out there. They're commonly used on IMSA and Nascar race cars along with many high end brake kits for other vehicle platforms.
These calipers offer tons of features not present with other options such as, stainless steel pistons, anti knockback springs, pad changes are just a matter of removing one bolt, there is just about every pad compound available for these calipers, pads are around the same cost as OEM brembos but the pads are much thicker so they last longer. The rotors have more thermal mass (32mm thick) so they'll last very long too; there will be options for both one and two piece rotors to give customers the ability to control their consumable cost, and best of all, we've balanced rotor diameter and piston sizes to make sure brake bias is changed less than 2% from the factory Si brake setup. We should have the prototype kit done in a few weeks! The photo below is just for mockup, I only had one spare caliper on hand to test fit with which is why it's upside down. If you guys have any questions about products or product requests feel free to post up here!
- NCM (Apr 15-16)
- Midwest Fest (Jun 2-5)
- Alpine Fest (Sep 8-11)
- Undecided 4th event
- L15B7 Si longblock
- Factory Si turbo
- 27Won cold air intake
- Modified factory catback exhaust
- PRL intercooler and charge pipes
- PRL flex fuel kit
- Hasport engine mount package
- MFactory 1.5way clutch diff
- Clutchmaster FX725 clutch
- MAP oil cooler kit
- KTuner V2 tuner
- BC Racing BR coilovers
- K Tuned toe arms
- DC5 Brembos
- Eibach rear sway bar
- Enkei NT03+M 18x10.5 w/255 Falken RT660 (F) 18x9.5 w/235 RT660 (R) (track)
- Enkei NT03+M 18x9.5 w/245 Hankook Ventus V12 (F+R) (street)
- Type R factory front seats
- Type R door cards
- Type R rear wing and hatch
- Evasive Type R rear wing element
- Acuity short shifter
- Acuity shifter bushings
- Acuity throttle pedal spacer
- Modified factory front fenders
- Mugen front lip
- 2020+ style upper grille
