FIX 86
Hsoj
Asheville
2017 Civic si
In the 10th gen civic si, is it overkill to use a fix 86 and a dsp or is.it necessary to flatten the signal from the HU and then feed that into a dsp to create the curve?
PandaXpress
EX-T with Honda Sensing
If you are going aftermarket speakers and amplifier you will need a DSP for summing all the channels bit if you want just a flat signal with no bass roll off you can hondahack your headunit and install Viper4Android
Hsoj
Asheville
2017 Civic si
Yea im going aftermarket speakers and sub so was wondering if I needed both the fix and a dsp
ebatr24
Oregon
Need is subjective here. It is up to you whether you feel it is needed or not. Can you run aftermarket speakers and an amp without it, yes. Could you potentially get better sound using the JL Fix, also yes. To add I used the Kicker Key amp which has it's own DSP and auto tuning feature. Worked out well and sounds really good. If you're considering a Fix 86 though it sounds like you're trying to build a higher end sound system
