FC3 build Dec 18'-Current
Turn10Photos
Turn10Photos
Jordan
Las Vegas
www.turn10photos.com
FC3 Si, FK7, HRV
  • #16
D2 Springs are in.
I will never touch the suspension on this car again. I'm not sure why, but the front assembly proved to be the biggest PITA. My prior experience didnt prepare me for the hell this front assembly proved to be. How did everyone else tighten the top strut nut back?
Total install time
Front- A week:banghead:
Back- 10 minutes.
Turn10Photos
Turn10Photos
Jordan
Las Vegas
FC3 Si, FK7, HRV
  • #17
Bunch of upgrades since Christmas
D2 springs
Acuity stage 2
Acuity pedal spacer (waiting arrival)
Tanabe strut bar
Whiteline RSB 22mm (waiting arrival)
Accord end links
Hood/roof/B-Pillar CF wrapped
Tsp stage 1
Avid1 av20 18x8.5 (black)
Boomba RMM 80a
AREA
Houston, TX
95 hatch Drag car, K20Z3 00 Integra, 07 Civic SI sedan and 18 Civic SI coupe
Looking really good man!
Turn10Photos
Turn10Photos
Jordan
Las Vegas
FC3 Si, FK7, HRV
  • #19
Few more upgrades/modifications.
Whiteline RSB installed.
Buttershift.com boot installed (PM me for special discount on site)
Wrapped shift area (avery sw900 CFiber)
Stickers & plate installed
Engine fender covers (ebay)
Anyone installing a short shift adapter will need to zip tie the link bushing. The shifter will "click" going into even gears (2,4,6) if you do not. Requires holes to be drilled in shifter mount. This is not difficult. ACUITY has a video showing how to do this.
Turn10Photos
Turn10Photos
Jordan
Las Vegas
FC3 Si, FK7, HRV
  • #20
Updates:
PRL FMIC powder coated black & installed. Special thanks to @FearTheH. Go VGK!
Driver side fog shroud removed and vented.
This had made a considerable difference in IAT temps. Average was around 10-12° above ambient. After drilling holes it dropped to 7-8°. Upon complete removal it has dropped an additional 1-2°. Temperatures drop much quicker now that the filter gets direct air upon the car moving.
FMIC was a must for the summers here. It will prove its use in the coming months.
Lastly, the setrab oil cooler was loosely measured and mounted. A longer return line will be needed, as well as the Greddy oil block adapter ($105). Sirimoto offers the Pedistal and relocater but the price is staggering. Will get this installed before summer.
I also measured the C&R racing radiator i have layng around. It is 3" shorter but 3" thick. Slim fans and custom shroud will be needed if i go that route.
Or a koyo lol.
Turn10Photos
Turn10Photos
Jordan
Las Vegas
FC3 Si, FK7, HRV
  • #21
Gold wrap installed. This is the cheaper variety and there was a slight difference already. Outside temp 78°. IAT 1 +10. IAT 2 +15. This was about 2° difference from normal, and it was rather warm .(+= above outside temp)
Wrap installed on:
TIP
Coolant lines
Brake reservoir
Hood right behind latch (where intake sits)
Charge pipe
New muffler and tip installed. Started off with a muffler delete....that lasted two days.
Magnaflow 14210 muffler. Muffler is designed similar to oem (and size) so it mounts perfectly.
Sound is deeper than stock. Stock resonator in place. The rasp from the cat delete is gone as the piping in the rear is now larger + larger tips.
All work was done by Manny at Downtown Mufflers. 702-366-0242. Tell him Jordan with the Blue civic sent you[
Ty3366!!
Tyler
Canton Ga
2020 Civic SI
Wrap installed on:
TIP
Coolant lines
Brake reservoir
Charge pipe
Damn dude. You should be a photographer bc these pictures are fire! 👌
