Favorite Brake Pads......GO!
martindtjr
Martin
Republic of California
www.flickr.com
TYPE R PMM 2019, Toyota Sienna XLE 2015, Scion Xa 2006
I forgot about the R-4S being dusty. I had them on my Galent VR-4.
winsanity324
@WNSNTY
2018 Civic Type R
Yes , one off the best brake pads in the world ,I drive them for 10 years on my Renault Megane RS , never have fading or brake problems on track ,pads are the same for the Honda , you have to buy the CC40 (new name for ME 20) circuit compound EP357
https://www.rhdjapan.com/endless-br...p9a-ct9-cz4a-g-b-g-f-ya5-vab-sg9-bes-b-5.html
Thanks for the reply!
Did you happen to daily drive on them at all? How were they for a little street use? Looking for something great At the track and still decent for a bit of street use.
dixie1
Dirk
Belgium
Renault Megane RS Lotus Exige V6 and soon Honda civic type R 2018
They work perfect for street driving , but they create more dust on street than on a track...
Muggsy
Gary
VA/DC
2018 PMM CTR, 2000 Lexus GS400
I just ordered the Akebonos from Rock Auto and they'll be here Wednesday. This will be my first DIY pad replacement (car has 25K miles) and the OEM pads are still good, but the brake dust drives me nuts and I want to change them this week when I put my NSX rims back on for the summer. Front pad change looks super simple but rears look a little more complicated. Do I need any sort of special tool to do the rears? I've seen conflicting advice online, so I'm asking those who have posted about installing the Akebonos. Thanks!
hpbyhermann
Hermann
Edgewater Maryland
2019 Championship white Type R #25133, 09' Civic SI sedan, black 2013 Boss 302 Laguna Seca, 1993 Mustang Cobra, 2004 Mustang Cobra
No special tools are needed. Just remember NOT TO SET THE PARKING BRAKE before starting the pad replacement. You will have to have access to some type of windback tool for the rear caliper pistons. Do a quick search and I'm sure that there are pictures and step by step instructions on here somewhere.:thumbsup:
hpbyhermann
Hermann
Edgewater Maryland
Read post #78 in this thread by JON, that is all you need there.
Muggsy
Gary
VA/DC
That's what I needed. Thanks! I will update after (I hope) a successful install.
Muggsy
Gary
VA/DC
Replaced the front pads over the weekend with the Akebonos when I was putting my summer tires back on. All good, no issues. Unfortunately I couldn't do the rear pads because I am waiting on the caliper wind-back tool. I ordered one from Amazon about a week ago, but shipping is delayed for non-essential items so it won't be here for another couple of weeks. I did take one of the rear calipers off to check it out, and the pad replacement looks pretty straightforward with the tool. I did note that the rear OEM pads are much more worn than the front pads, which were still in pretty good shape after 25k miles.
hpbyhermann
Hermann
Edgewater Maryland
If you want to do the rear pads now you can use a set of needle nose pliers to windback the caliper pistons. :thumbsup:
Muggsy
Gary
VA/DC
Thanks, I actually tried that briefly because I had seen your suggestion. I got the caliper moving but couldn't get the pliers firmly set in the notches and decided I didn't want to risk screwing it up. I will need to wind back the pistons a good bit because the rear pads were pretty worn. I can wait for the tool, particularly since I'm not really driving anywhere at the moment.
hpbyhermann
Hermann
Edgewater Maryland
You can get a cheap "cube" at any local auto parts store. Another option.....used with a 3/8" ratchet and extension. I keep one at home for emergencies!!:headbang:
Muggsy
Gary
VA/DC
Just did the rear pads this afternoon after I got the wind-back tool from Amazon yesterday. It wasn't bad, except a bit tricky to get the caliper back over the new pads even with the piston fully retracted. I did it by screwing one of the caliper pins back in and seating the inside pad within the caliper, then rotating the caliper onto the rotor. Drove around a bit and the brakes still work so I think I'm good. Looking forward to much less dust on my NSX wheels this summer. Thanks to all for the guidance!
fk8dc5s
Alex
OC
2019 FK8 2003 DC5S 1994 CD5
I hope you folks are retracting the electronic parking brake before attempting to push back the pistons in the rear. if you have a good scan tool they can set the car to maintenance mode for the EPB system. if not you must remove the electronic motor manually and retract using a an Etorx 11mm. other than that you can damage the system. I did my rears last week manually and it was super easy. I did not need a piston tool. I used my 2 thumbs to push and that was all. with the EBP retracted all the way its that easy. without retracting you are forcing it back with the tool. no good.
Tev42
Tyler
Baltimore
2019 CTR
Hey Guys and Gals!
Wanted to update you on my brake pad selection and results. Dory now has over 41,000 miles and on her 3rd set of pads! :headbang:
I replaced the OEM with Hawk HB453N.585. Again, I DD my CTR and track a few times/year. THESE pads were wayyyyyyy better than the OEMs on the track! That was a pro. The cons......VERY dusty and noisy! Squealed intermittently and was annoying for DD. Pads lasted just over 20,000 miles and that was with 2 track days. I recently put on Project Mu Type PS F906. I LOVE THEM! Quiet and wayyyyyy less dust! Haven't been to the track with them Yet but the garage owner I go to races a GTR and an S2000 and swears by these pads!
Just another option for those who DD and track occasionally!
Have a GREAT day!:nixon:
Any feedback with the Project Mu's on the track
