Fatherpain’s 2018 Type R
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 60093D6B-C24B-473B-B835-226283D2B844
It Remove these hoses from the thermostat and it’s housing. The housing bolts are long and just need to be backed out. They can remain in the housing as it just needs to be pulled back about (1) inch to get the water pipe out.
Honda Civic 10th gen Fatherpain’s 2018 Type R F68FDFAC-64BE-4F06-9898-DDF82C056511
This bolt securing the water pipe to the thermostat housing was pulled earlier.
Honda Civic 10th gen Fatherpain’s 2018 Type R A6ACC9F4-F799-40CE-BEEE-6A7FD90D205D
Pry the thermostat housing back to obtain clearance for the water pipe to clear. Use a pry bar to separate the pipe from the housing.
Honda Civic 10th gen Fatherpain’s 2018 Type R 713CCB1B-7579-4F4B-92CC-92618A5FAE30
And out it comes.
Honda Civic 10th gen Fatherpain’s 2018 Type R 4E2EC30D-D18F-4984-9C45-C6F1DAEAAA7D
The other end was a little stubborn so sprayed some penetrant to help loosen it up.
Honda Civic 10th gen Fatherpain’s 2018 Type R 2953FC50-B2C5-48C0-8568-B800F62D479C
Voila! OEM water pipe removed ?
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R A88CD03D-BE89-419F-A14E-0524EAAC53BD
The sealing surface where the water pipe contacts the thermostat housing had a build up of a hard scale that resembled pitting.
Honda Civic 10th gen Fatherpain’s 2018 Type R FCB700A1-0C58-4BCF-BBD6-1F99406A2ED3
So scuffed it with some 240 grit sandpaper
Honda Civic 10th gen Fatherpain’s 2018 Type R 18E1AC30-F442-4C2D-9251-5DA1FC15F9A6
Smooth again. :)
Honda Civic 10th gen Fatherpain’s 2018 Type R 764DD66E-F874-4662-95A8-0588A1C5A6FD
Transfer this metal thimble and rubber grommet from the OEM water pipe to the new one. I forgot to do this so had to redo, once I realized my mistake. This cannot be done in place. :doh:
Honda Civic 10th gen Fatherpain’s 2018 Type R 9F88D013-3F9C-4E74-8167-A114BAD4713D
Kroil or WD40 will help with pressing the grommet off.
Honda Civic 10th gen Fatherpain’s 2018 Type R FA58DE74-2193-4400-A1CC-E238DE9DA8AB
Grommet and thimble removed. Ready to reuse.
Honda Civic 10th gen Fatherpain’s 2018 Type R EA42432E-00B5-40CD-B349-726A634E3964
Dream hard lagged water pipe and (2) new o-rings.
Honda Civic 10th gen Fatherpain’s 2018 Type R 7B7DB942-1590-4C88-8491-D3133E663DED
It’s good practice to apply o-ring lube for longevity and ease of installation.
Honda Civic 10th gen Fatherpain’s 2018 Type R 4098B538-3DC9-4E52-B2C6-CA309D8E0CBA
O-rings installed to the new pipe.
Honda Civic 10th gen Fatherpain’s 2018 Type R 70339E2C-6223-48B4-8EA3-3D2402F8D6A6
Insert the pipe into the fixed drive belt end.
Honda Civic 10th gen Fatherpain’s 2018 Type R 793C518D-6B12-42A4-B98E-D755592A67AA
Then line up this end to the guide pin.
Honda Civic 10th gen Fatherpain’s 2018 Type R 1578B7BA-FC57-4698-9650-58DA468BBADA
Use an acid brush to apply o-ring lube to the thermostat housing rubber seal.
Honda Civic 10th gen Fatherpain’s 2018 Type R 9C3E94D8-420E-4A03-A9C8-577DA6D670B6
This is a photo from my first attempt. Had the grommet been there, I’d have screwed the bolt back in.
Honda Civic 10th gen Fatherpain’s 2018 Type R 0AEE07EE-11FD-4DEF-B596-8EA16A0FBCBE
Woohoo! Dream Automotive hard lagged water pipe installed! That previously missed grommet and bolt are in place now. Won’t bore with the reassembly details which is just the reverse of what I’ve posted.
Just remember to apply anti-seize to any fasteners and tighten everything evenly and snug. Bolts don’t need to be killed where they strip aluminum. I asked my Honda tech nephew about torque settings and he said they just go by feel, so that’s what I did. Hopefully no leaks when I’m done, or I’ll be back under the hood again ?
This is a pretty involved process to swap the water pipe. More so than anticipated when I picked this up several months back. Am glad it’s finally in and fully expect the temperature gauge not to move off normal next time I hit the track. We’ll see.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R EE091F89-23E0-4F33-8E62-C45D162A439A
With the water pipe odyssey complete, had some momentum so moved to reinstall the factory turbo wrapped in the Dream Automotive hard lagged heat shield. I had previously secured the cladding using (2) 8mm x .125 allen head screws with flat washers. Had to re-use this gasket as it also is currently unavailable for purchase. Cleaned up both sides of it and discarded this paper towel.
Honda Civic 10th gen Fatherpain’s 2018 Type R CA8A3AF8-9EDC-4757-9B4F-0954665645BB
Fished the turbo into position and began bolting in on. The damaged DP stud was machined out and replaced with a Rampage Ti.
Honda Civic 10th gen Fatherpain’s 2018 Type R 0C1532B5-F0AC-4F5A-9512-5C16ABF20509
Unfortunately, I was unable to get this final bolt started due to interference from the lagging.
Honda Civic 10th gen Fatherpain’s 2018 Type R 64DF7A1E-7548-4B92-B322-88D608A4FBB5
Had to disconnect the waste gate linkage to allow for more adjustment, so made some match marks in case it were to spin or whatever.
Honda Civic 10th gen Fatherpain’s 2018 Type R 0B8DB2C1-5483-42F1-855F-6C0E60C64C4A
Loosened the actuator bolts using an Allen wrench.
Honda Civic 10th gen Fatherpain’s 2018 Type R 41345DF8-5D64-4324-8830-8AF2CA4F0C1D
And backed them out this much, to create a gap for the actuator. No need to completely remove.
Honda Civic 10th gen Fatherpain’s 2018 Type R A88B0DD3-33DA-46A8-A8D9-CFEBF6A8A5A7
The wastegate linkage easily slides off with the retaining pin removed combined with the actuator play.
Honda Civic 10th gen Fatherpain’s 2018 Type R 5AB333A6-A71E-49FF-B9B4-86C19AE5402A
Was then able to maneuver the cladding back enough for the bolt to start and tighten using a 14mm combo.
Honda Civic 10th gen Fatherpain’s 2018 Type R AE17910E-96F2-441D-8F5B-3A51EA71204A
Then encountered an issue with the shield material hitting the top left stud, preventing this bolt hole from lining up. :confused:
Honda Civic 10th gen Fatherpain’s 2018 Type R C772D59B-CD89-43B5-A74D-F3E007DBEFCF
Tried to lightly persuade it. And though it looks good here, the bolt hole still wouldn't line up. Solution was to undo the 2nd Allen bolt underneath (not pictured). Once free, was able to get the top bolt started, then redid the bottom bolt to secure the cladding.
Honda Civic 10th gen Fatherpain’s 2018 Type R D45733A5-5098-46E0-B94D-52451D0EBFAD
The heat shield then rubbed against the wastegate arm, so used a flat screwdriver (a punch would have been better) and hammer to move it away so the arm could move freely.
Honda Civic 10th gen Fatherpain’s 2018 Type R 4B042944-E335-4E4B-A54F-C47A7450CEFB
Used a new gasket for the water lines going to the turbo.
Honda Civic 10th gen Fatherpain’s 2018 Type R D75736A6-7837-4046-A269-44CE8B1DF4F4
And this new gasket as well. The O-rings for oil lines are not available. I opted to reuse, though it probably would be easy enough to source the correct sized O-ring.
Honda Civic 10th gen Fatherpain’s 2018 Type R 7EB12919-1A97-44FE-8822-27C6E25C2623
Re-secured the wastegate actuator, linkage and pin. The (2) top and bottom Allen head bolts holding the hard lagging in place are clearly visible in this photo. Reinstalled the hoses and turbo support bracket.
Dream Automotive hard lagged turbo heat shield installation also complete. :thumbsup:
fatherpain
fatherpain
Tom
Thank you @chrisspeedy. Apologize on the slow progress and updates.
I get in trouble with the family, when spending too much time working on the car, so have to strategically pick and choose when to do it.
Due to the arcade collection, wrenching on the car in the garage is a no go…. So the car is staged outside and weather is a factor. Don’t have much motivation when the weather is hot.
Mornings are my preferred time to mod. My energy level is highest, temps are cool and there aren’t as many mosquitoes. However my wife started working nights to save for our kids college funds. Morning is when she’s home, so that time frame kinda got nixed. 😢
Started this round of mods back in August and I’m just plodding along….it’s hard to find time between family, work and extracurriculars to devote the time needed to make serious progress, but hey, I’ve fixed the refrigerator, washing machine and the shower valve. Wouldn’t hear the end of it, if time was spent modding while those weren’t working.:rolleyes:
Hoping to resume tonight, if the weather isn’t too hot. Wish me luck ?
I like how detailed this build thread is, I am excited to see the outcome.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R F67529A4-DCD2-4416-A726-06B5A55C4FE3
Prior to the FK8, my automotive repair experience was limited to occasional oil changes, even though I was a mechanic at a power plant….
With that in mind… this next mod is to change out the oil pan to a Unit2 Fabrication baffled oil pain… err pan :drool:
To be clear, this oil pan looks like a great product. Workmanship is beautiful and promises to prevent oil starvation under hard track driving. My tuner, Ben (Salasko Racing) says a baffled oil pan is a very worthwhile investment for a track build. :cool:
Honda Civic 10th gen Fatherpain’s 2018 Type R 8C1DB771-3240-4E68-8579-AFB7798E819F
A look at the OEM oil pan. Interestingly, this mod, combined with the OEM water pipe upgrade draws upon pretty much everything I’ve learned modding the FK8 to this point (and then some). From this vantage point, the RV6 front pipe needs to come out along with the Hasport RMM. The Dream Downpipe was previously pulled for the water pipe install.
Honda Civic 10th gen Fatherpain’s 2018 Type R 1C632F12-0724-4D89-B21F-CB78CC943108
The HKS oil cooler sandwich plate and filter will need to come off, as will the serpentine (alternator) belt and AC condenser motor. What the heck have I gotten myself into? I knew there was as a subconscious reason I’ve been procrastinating on these installs, haha :doh:
stariq812
Fairfax, VA
2020 CW FK8
To be clear, this oil pan looks like a great product. Workmanship is beautiful and it promises to prevent oil starvation under hard track driving. My tuner says a baffled oil pan is a very worthwhile investment for a track build. :cool:
You have literally perfected this car which perfect to begin with
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 3B273F6F-AC63-4CE2-B577-8EB6AFB51664
Where to begin? Sheesh… might as well start at the top! ?
Honda Civic 10th gen Fatherpain’s 2018 Type R BC156C05-2E25-447F-8FC5-41485B73EEC1
Gotta get the Radium CCV catch can out of the way, to access the belt tensioner on the Serpentine belt. Disregard this step if do not have this mod.
Honda Civic 10th gen Fatherpain’s 2018 Type R AE478A89-6DA9-4940-BD36-3DDC51010EFF
The purpose of the belt tensioner is to release tension, so the belt can be removed from the pulley. I’ve marked it in blue. Figured out how to do this watching YouTube. :bow:
Honda Civic 10th gen Fatherpain’s 2018 Type R C5C41F59-358A-4186-A707-886DFE962C35
This is a close up look at the belt tensioner.
Honda Civic 10th gen Fatherpain’s 2018 Type R 1A93D2B6-440A-4846-97A4-EF938CE604CB
Another angle. The idea is to rotate this forward towards the front of the car and the belt tension will release… it only needs to be moved maybe (1) flat or so. It’s spring loaded so will go back to it’s starting position when released. There isn’t room to use a ratchet and socket… so will need to use a modified thin breaker bar, or (2) combination wrenches. Size is 17mm
Honda Civic 10th gen Fatherpain’s 2018 Type R 67582B6A-4BB3-41AA-AF86-1B251F78C2E7
This is the method I used…box end of the 17mm combo wrench on the tensioner hex… then the box end of a 2nd combo grabbing the open jaw to serve as an extension to give the needed leverage. This was the starting point, at rest.
Honda Civic 10th gen Fatherpain’s 2018 Type R B2BBEFEE-C75D-4260-939A-87544DD04FF2
This is how much is needed to pull to release the tension. Be careful not to pull too far and damage the AC line.
Honda Civic 10th gen Fatherpain’s 2018 Type R 74D19DEF-AA3B-44B3-8A4F-DDC196523020
With the tensioner pulled back, carefully slide the belt off the pulley.
Ideally, use a long flat screwdriver to move the belt and not fingers that can be severed if something were to go wrong ?
Leave the belt like this and don’t remove… note how the belt is routed on the pulleys so it can be put back correctly. Just in case :headbang:
Honda Civic 10th gen Fatherpain’s 2018 Type R 06522D8A-DCBB-45DC-8126-7DF56C69C599
Then remove this turbo piping and silicone hose to the intercooler and disconnect the rubber turbo oil line to the pan.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 0AA0601D-CCA6-488B-AE5C-6FE446E4BB87
Removed the un-tensioned serpentine belt from the AC compressor pulley also.
Honda Civic 10th gen Fatherpain’s 2018 Type R 124FF9AE-DC49-4660-A3ED-E609E24BC6F2
Back underneath, these (2) bolts securing the AC compressor to the oil pan need to be removed.
Honda Civic 10th gen Fatherpain’s 2018 Type R F8433BDC-29E2-4DD1-B50F-93B9EEF3F5A1
Like this.
Honda Civic 10th gen Fatherpain’s 2018 Type R 30D93F54-C813-4088-8C11-6F47989E4472
There are (2) additional bolts on top of the AC Compressor that are difficult to reach. Here is one of them. Opted to back out and not fully remove as didn’t want to yank the condenser and a real tough spot to reinstall if completely removed.
Update: it would have been much easier to pull the bolts after all. The AC compressor sits on a shelf that serves as a hook. Undo the compressor bolts, lift off the shelf then the compressor can be pulled away to give room to pull the oil pan, or it will fight you. This absolutely needs to be done on reinstall.
Honda Civic 10th gen Fatherpain’s 2018 Type R 83002C01-F633-4450-A6B3-C6A7D08C9111
Here is the 2nd upper AC compressor bolt. Can see and access it through the passenger fake vent opening using an extension and 12mm universal socket
Honda Civic 10th gen Fatherpain’s 2018 Type R F6F88081-84F2-410B-BF73-7563821A651D
Close up of the rat bastard.
Honda Civic 10th gen Fatherpain’s 2018 Type R 022D3F00-5DC7-460B-8B9A-79F8514B7DD4
Used a tweaker to slide the orange lock tab on the AC compressor electrical harness.
Honda Civic 10th gen Fatherpain’s 2018 Type R 4F066A7D-A3C3-4CC6-8A5F-B93A84FA0B23
Then depressed and disconnected the plug to be safe.
Honda Civic 10th gen Fatherpain’s 2018 Type R 93942C1F-9A12-4CA1-AC76-85C0A8911D82
Removed the oil filter.
Honda Civic 10th gen Fatherpain’s 2018 Type R D933F0C4-E253-4E40-B1AA-0A5E295DCE3D
Then pulled the HKS oil cooler sandwich plate. The retaining bolt takes a 19mm socket. Torque setting is 47 ft-lbs when time to reinstall.
imagine anyone considering this mod would also have an oil cooler.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R B95D504C-AE76-4DCA-9F39-C40329C8959E
Removed all the small bolts holding the oil pan to the engine block using a 10mm socket, ratchet and extension. Note: (2) are shorter than the others. Didn’t notice until they were all out, so will have to check to see which ones when reassemble.
Honda Civic 10th gen Fatherpain’s 2018 Type R D6E6E872-8AA8-49D7-BE7A-0F69E18BD195
This particular bolt used an extension and thin walled 10mm deep socket.
Honda Civic 10th gen Fatherpain’s 2018 Type R 3164D54F-3399-414A-B8B8-5CC4FDD6EED2
This one used an extension, regular 10mm socket and universal adapte
Honda Civic 10th gen Fatherpain’s 2018 Type R 17E85F6A-025E-442D-824A-70A9826E277A
This cover is held on by (2) bolts and needs to come off.
Honda Civic 10th gen Fatherpain’s 2018 Type R 23931616-49D4-454D-8383-36BEA329A072
Like this.
Honda Civic 10th gen Fatherpain’s 2018 Type R DB5694D5-E49B-48D3-9D5A-F1F94B750F95
With the cover out of the way, these (2) bolts can now be accessed. Continued until all of the small bolts were removed from the oil pan.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 986A0A24-CADE-4CB6-BCA0-FBB90B9EBB13
Disconnected the RV6 front pipe from the exhaust piping.
Honda Civic 10th gen Fatherpain’s 2018 Type R E927EE8C-3D68-484D-89FF-60288568A685
In order to move the FP down and out of the way.
Honda Civic 10th gen Fatherpain’s 2018 Type R 0B57FFA9-0A78-47EF-B93B-ED5897C8624E
The RMM also needed to come off. The pin used a 19mm socket.
Honda Civic 10th gen Fatherpain’s 2018 Type R FEE1B7F8-EA20-4EE2-B592-1A116DF4D198
And 17mm socket here.
Honda Civic 10th gen Fatherpain’s 2018 Type R 147D076E-8067-48AC-8366-1B03A1E2E819
Lifted the engine a little and wiggled the RMM out. Here is the Hasport 62A after about 20k miles of service. A little dirty but still in good shape. :headbang:
Honda Civic 10th gen Fatherpain’s 2018 Type R A1B05A1E-5BED-4EDC-9E61-F74456BDB09D
With the RMM out of the way, used a 14mm socket to remove the RMM bracket because there is a bolt behind it that needs to come off.
Honda Civic 10th gen Fatherpain’s 2018 Type R 170124C1-8D84-42E2-B68D-3A7B7ED8D2BA
With the RMM bracket removed can now see and reach it.
Honda Civic 10th gen Fatherpain’s 2018 Type R 79D4C358-2BAA-4BA7-B126-D9E7CF112E2F
These last (4) bolts holding the oil pan to the side could then be removed using a 14mm socket.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R C61E0B24-A607-483E-AB57-8BFB2CD2AF93
Verified all oil pan bolts removed. Inserted a pry bar Into this recessed notch and gently broke the Honda bond seal and pried the pan away from the engine. Was careful not to mar and damage the soft aluminum faces.
Honda Civic 10th gen Fatherpain’s 2018 Type R 90C0ACF9-2ACE-4427-8AD0-E52B3C4C9CB0
The oil pan didn’t just separate and pop off. It required a bit of patience and finesse as it sandwiches the engine with the turbo oil line on one side and the AC Condenser on the other.
Honda Civic 10th gen Fatherpain’s 2018 Type R B07665AD-BA87-4C96-BA84-8745682FA22A
Whoa ? the eagle finally landed! :thumbsup:
There was a small amount of oil remaining in the pan and it did not spill. More importantly there were no metal flakes or chips in the pan. :headbang:
Honda Civic 10th gen Fatherpain’s 2018 Type R F7B418BA-B8EE-4CC9-B3B9-FE78C643CCBB
OEM oil pan removed!!! Yeah baby yeah!!
:dance:
turbociv910
taylor
wilmington nc
Wow the pictures are amazing. Do you have any of the vacuum pump? was quite curious of how all the looks under the covers.
If selling the oem oil pan let me know!
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 23247EC1-2923-4D2B-9B7A-B9F833A0981E
Honda Civic 10th gen Fatherpain’s 2018 Type R EADBF836-66DF-4885-ADD7-D84AE40F0942
Honda Civic 10th gen Fatherpain’s 2018 Type R 63D09F09-E0DB-4E27-AC74-2A24E29A1B12
Honda Civic 10th gen Fatherpain’s 2018 Type R 2CA4EC28-FEA8-4C80-BE70-D9302FE0D944
Honda Civic 10th gen Fatherpain’s 2018 Type R CDBCCA22-1AF3-4FD0-908F-D3C38DFAC1EB
Honda Civic 10th gen Fatherpain’s 2018 Type R 2F94D3A1-37F3-4812-A2D8-43AF26BDB14D
Honda Civic 10th gen Fatherpain’s 2018 Type R 81D494B9-88B9-44C3-BB80-E16FCE15F898
Honda Civic 10th gen Fatherpain’s 2018 Type R 415061DB-0F50-4F5F-8824-225AC3C8C18F
Honda Civic 10th gen Fatherpain’s 2018 Type R 5CBFD34A-EBDB-4772-A4DA-10D811512108
Here you go Taylor. Hopefully I put it back together correctly and it still works. ?
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R C9DD2E69-B39F-4651-ABEC-9E2EFCA2C210
Under view of the engine with oil pan removed.
Honda Civic 10th gen Fatherpain’s 2018 Type R 05AB400C-EB87-479E-99E2-2631134FA4A4
Note the chain linkage on the passenger side.
Honda Civic 10th gen Fatherpain’s 2018 Type R 9244E609-C6F8-41B3-A0EA-1B9BAC16E7E6
Found the AC compressor needs to be pulled back for the new pan to fit. Doing this first, would have made removing the old pan much easier.
Honda Civic 10th gen Fatherpain’s 2018 Type R 7F714075-82F5-482D-8C00-1AB9D6640ADD
One of the two AC compressor top bolts to remove. This is the easy to reach one.
The lower bolts were already taken off and electrical connector separated. Note the jigsaw bracket the compressor rests on.
Honda Civic 10th gen Fatherpain’s 2018 Type R DA6F2230-851A-4F55-8DFD-660FEFEF33EF
Accessed the harder to reach top AC compressor bolt through the passenger vent. Size is 12mm. Another way would be to pull the radiator for more space, but didn’t find it necessary.
Honda Civic 10th gen Fatherpain’s 2018 Type R C6CD8487-6869-456D-B597-364492F9E36A
Looking down at the final top bolt completely loose and backed out.
Honda Civic 10th gen Fatherpain’s 2018 Type R 976C55F2-67F1-44B4-8A35-79D6AEB4063F
AC compressor lifted off the jigsaw bracket and pulled towards the front of the car.
Honda Civic 10th gen Fatherpain’s 2018 Type R B8B94C77-AEAD-4FE9-BB77-2EEF324933C9
Used daisy chained zip ties to hold the compressor out of the way.
Honda Civic 10th gen Fatherpain’s 2018 Type R 5B3694C4-E16A-4F73-8BD2-16DC2F5F9343
The old yellow sealant could be clearly seen. The pan doesn’t have a traditional gasket.
Honda Civic 10th gen Fatherpain’s 2018 Type R 88E8D853-E151-4635-AF2A-39590C998C09
Used a fresh razor blade to scrape the old silicone off and clean the sealing surface. Sprayed with contact cleaner and wiped off with a paper towel afterwards.
