Fatherpain’s 2018 Type R
Back2Honda
Ron
Rosemead, CA
2018 Civic Type R, 2004 Subaru Wrx STI, 2004 Infinity G35
Hello Tom, been trying to catch up on your journal. If you like the A052's, I would highly recommend you try out the Nakang CR1 tire. I heard they're as sticky but last much longer. I currently have them on my car and all I can say is wow. I feel super confident on track with these.
I was thinking of the Nankang CR1 but was recommended the Falcon RT660 because the can be rotated since the tread pattern is symetrical and will have similar performance at 200tw.
fatherpain
fatherpain
Tom
Hard to believe it’s been (7) months or so, since I’ve last wrenched on the car. Now that I’ve reached a comfortable stopping point with the arcade hobby…. It’s time to move forward on several mods that have been languishing on the shelf..
It’s been difficult getting psyched up to work on the car again. When I start something, the OCD kicks in, and it’s hard to step away until it’s complete.
My wife knows and will guilt trip saying I’d rather spend time with the car, than my family. That’s totally absurd? Right? :rolleyes:
Well… ok maybe not. Haha. :drive:
This round of mods will include:
  • Dream Automotive hard lagged turbo heat shield
  • Dream Automotive hard lagged water pipe
  • Updated Eventuri CF turbo inlet tube
  • Unit2Fab baffled oil pan
  • Oil temperature and pressure sensor install (will not connect until I’m able to purchase a Motec 125 dash display, like my buddy @turbociv910 is rocking)
  • XDI HPFP
+ brake pad change, fluid change, oil change, radiator flush.
Honda Civic 10th gen Fatherpain’s 2018 Type R D0988D96-3937-47A3-A73A-AD8FEFE67A83
First thing I wanted to try is the EZ Car Lift ground clearance kit… which are aluminum ramps the car that provide extra height to increase the starting leverage of the EZ Car Lift. Hopefully, the internal bolting won’t bend like it did previously. These will also be needed so the lift can slide underneath when the car is lowered in the future. There are stops at the top so the car doesn’t shoot past and fall off.
Honda Civic 10th gen Fatherpain’s 2018 Type R B7652D23-9684-48C1-8330-9C5E80FE97CA
The ramp then detaches so the EZ Car Lift has room to fit under the jacking points.
Honda Civic 10th gen Fatherpain’s 2018 Type R DBE7906B-39C3-4A05-8C95-D73F3EB52FEC
Tires pulled for brake pad maintenance and flush.
Honda Civic 10th gen Fatherpain’s 2018 Type R D612942A-BD4C-4415-BBBF-CAC6A9DA1C54
Bumper, under plastic and oil tray removed.
Honda Civic 10th gen Fatherpain’s 2018 Type R E8E05933-13E7-4511-887B-AD4747B90EE3
Radiator fluid and oil drained.
Honda Civic 10th gen Fatherpain’s 2018 Type R 030EE8F5-9EAE-48E0-9F10-51CD0AABD569
It’s all coming back, quick as a whip. Battery disconnected. Ready to rock. :thumbsup:
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R D3D03024-79C0-4E18-B6DB-63164E5644CE
I’ll list the steps, but won’t go into full detail, as these have been covered in detail on previous posts. Removed the (3) APR CF cooling plates.
Honda Civic 10th gen Fatherpain’s 2018 Type R EDB40CBC-5794-494B-B0BE-B684C47B9183
Removed the Eventuri intake and swung the top radiator bracket out of the way.
Honda Civic 10th gen Fatherpain’s 2018 Type R 57599F8F-1397-4846-A317-E90ADB471152
Removed the Eventuri CF inlet turbo tube and Radium CCV catch can tubing.
Honda Civic 10th gen Fatherpain’s 2018 Type R 2D229EF5-C379-4486-8618-625323439F53
Pulled the Dream Automotive DP. Fortunately the bolting hardware came apart easily. No heating/cooling needed. The hard lagged insulation has held up well.
Honda Civic 10th gen Fatherpain’s 2018 Type R 65A1C951-41A9-41F8-A28F-02FF51489F17
The red ❌ is the OEM water pipe that is to be replaced.
Honda Civic 10th gen Fatherpain’s 2018 Type R 68D25010-0A1D-4CA7-A54D-EB4E676A5A28
Turbo needs to come off to access it.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 706C75C9-07A2-4A8B-9A03-FFFE68B45640
Turbo removal​
Honda Civic 10th gen Fatherpain’s 2018 Type R F8F0E9DE-2D8C-405D-ADDE-711C92156240
Remove these (2) bolts and support bracket from underneath the turbo. Believe these are 12mm and 14mm bolt heads. A ratchet extension or deep socket works well.​
Honda Civic 10th gen Fatherpain’s 2018 Type R 6A098DD9-1CDA-4C4A-A842-296303E7C57E
Use a metal toothbrush to clean rust from the threads on the backside of the turbo housing where one bracket bolt penetrated… then spray with Kroil.​
Honda Civic 10th gen Fatherpain’s 2018 Type R 4C6AB0E4-F2ED-4D0D-93C3-82C724F5E8FD
The lower bracket bolt was a little stubborn, but got it out with a breaker bar and 14mm deep socket. Heat was not needed. :)
Honda Civic 10th gen Fatherpain’s 2018 Type R B37E2560-62F1-4D86-B469-AAA9B457275A
Kroil these (2) nuts securing the water lines to the turbo and remove using a 10mm combo or ratchet.​
Honda Civic 10th gen Fatherpain’s 2018 Type R C44D4022-F462-4216-82F5-4CDD6CC3384C
Even with the radiator drained, there’s a good amount of fluid in the lines, so be ready to capture it or clamp off the rubber hoses. Recommend separating this before the oil or intercooler piping to avoid radiator fluid spilling into either. There is a gasket that will need to be replaced when it’s time to go back. Order these from hondapartsnow or the dealer parts department.​
Honda Civic 10th gen Fatherpain’s 2018 Type R 79BC375E-59B0-44BB-913F-D326F8A45E2C
Use pliers to compress and pull back the spring clip on the oil line.​
Honda Civic 10th gen Fatherpain’s 2018 Type R C5D5C7A4-505E-4C92-BA69-443D000436F7
Pull the hose off. Oil won’t spill if the reservoir is drained.​
Honda Civic 10th gen Fatherpain’s 2018 Type R 16F269F2-50FB-47F2-B551-9A46D9D60D6C
The other oil line comes off after this 10mm bolt head is removed. There is a o-ring that will need to be replaced when it’s time to reassemble.​
Honda Civic 10th gen Fatherpain’s 2018 Type R 200E6BC6-658C-492C-A696-19F5027C021F
These (2) 12mm bolts securing the intercooler piping to the turbo need to be removed.​
Honda Civic 10th gen Fatherpain’s 2018 Type R 923BB0FB-8BDE-4BAC-88FA-66FEDCCA874A
Broke the bolts loose with a ratchet and extension from underneath the car. If have an oil cooler, Disconnect the cooler lines for more room to work.​
Honda Civic 10th gen Fatherpain’s 2018 Type R B1BDA122-3836-43C6-A7E1-4766CF6B05D3
A deep socket was useful for backing the bolts out the rest of the way. Remember, do this step after the water lines. I did this first and radiator fluid spilled in and made more work as I had to clean it out. :doh:
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 9A3C9E53-D3B1-456E-8B80-51BCFECABBE6
There are (2) vacuum lines that need to be disconnected from the turbo’s cold side. Follow them and disconnect where convenient and accessible. I chose here. Use pliers to pull the spring clamp back and separate the hose.
Honda Civic 10th gen Fatherpain’s 2018 Type R 0930764E-AEA2-44E0-995A-025BC3867AC0
The lower vacuum line was tougher. This looked like the best spot… but my hands are small and can fish in to reconnect when it’s time to go back.
Honda Civic 10th gen Fatherpain’s 2018 Type R CEDF5FD4-E53D-49E0-BA90-FF399A3AC8A8
Had to use a flat screwdriver to push the vacuum tubing free.
Honda Civic 10th gen Fatherpain’s 2018 Type R 339DC5F5-197B-41F2-B184-FA57BC50D8FB
Squeeze and release the waste gate actuator electrical plug.
Honda Civic 10th gen Fatherpain’s 2018 Type R 6CD3822F-2ECC-4B76-9845-C4FB35E25CA3
Last to remove before the turbo comes off are these (2) upper nuts.
Honda Civic 10th gen Fatherpain’s 2018 Type R 2F60DB91-03D5-427D-A0F9-5CE975D6B792
Breaker bar and 14mm deep socket worked perfect for the lower bolts.
Honda Civic 10th gen Fatherpain’s 2018 Type R 8F2A75C4-24D5-45FF-AEDB-78B0A722B0A2
Carefully push the water hoses aside and finesse the turbo off. Voila! Turbo removed :cool:
Honda Civic 10th gen Fatherpain’s 2018 Type R EC86AB01-B371-4B92-B050-1CDBFC7045B2
Engine bay with turbo removed. OEM water pipe is now unobstructed :)
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 478BF3C1-469F-4881-931A-2661F6A6215C
With the turbo pulled, had a galled stud machined out. The damage occurred during a previous DP installation. Will replace with a Rampage Ti stud.
Here is the Dream Automotive turbo heat shield install.
Honda Civic 10th gen Fatherpain’s 2018 Type R B56C7E85-8335-4C79-95C2-F6F80EA60E5A
This is a good orientation for the task. Hot side of the turbo down. The linkage needs to be disconnected for the heat shield to fit.
Honda Civic 10th gen Fatherpain’s 2018 Type R 1205024D-CEF8-472A-934B-9F246202C52E
Remove this retaining pin.
Honda Civic 10th gen Fatherpain’s 2018 Type R 3511B8DB-1845-4018-BCFB-0D426FE105B8
The linkage won’t come undone with just the pin removed, so use a 3mm Allen to remove the actuator screws. Note the position of the linkage and arm.
Honda Civic 10th gen Fatherpain’s 2018 Type R C750CE4C-9C49-4FAB-B79B-DD6C515AEE1E
With the screws undone, the linkage can be wiggled loose. The waste gate arm drops, but that’s no big deal.
Honda Civic 10th gen Fatherpain’s 2018 Type R A865588B-96BC-438C-89F8-FF57793311ED
Lift the actuator out and note the position of the arm. Be careful because the arm can rotate freely and don’t want it to change position. Dunno if that matters or not, but knowing my luck, would rather not risk it. ;)
Honda Civic 10th gen Fatherpain’s 2018 Type R E1C884B9-90FD-4B80-836C-B43C7F36D774
The top half of the heat shield slides in and is a perfect fit. There is a bolt hole to line up to keep it in place. The (2) bolts needed for this kit are not provided ?‍♂ . Will determine what they are and provide an update.
Honda Civic 10th gen Fatherpain’s 2018 Type R 3FDE5D89-6E83-44C9-BACD-EB2B2E3B860B
Here is the backside piece in place. Again fitment is superb. :headbang:
Honda Civic 10th gen Fatherpain’s 2018 Type R F558796C-08F2-4FDD-9857-D48A4246B2E7
With the hard lagging in place, re-engage the linkage, insert the pin and secure the actuator screws. Make sure the electrical connector and linkage arm are pointing the right way. The actuator is a plastic type material so do not over tighten.
Honda Civic 10th gen Fatherpain’s 2018 Type R 61E422C2-8701-4068-8E53-7E08F057A771
Dream Automotive hard lagged heat shield installed. Dream claims it will reduce 1000F down to 200F so it’s functional and beautiful ?
Honda Civic 10th gen Fatherpain’s 2018 Type R 00F936D2-1972-4933-B92F-58BD587BBB13
Another angle :)
Gmedalion
19 FK8 and other Hondas (only 50 characters?)
Great build tread but that game room ??. Need to stop by for that, when’s the next meetup. Wow.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 3956600B-7E2B-444A-A1E0-25F817531E84
Side by side comparison of the Dream hard lagged water pipe to the bare OEM pipe.
Honda Civic 10th gen Fatherpain’s 2018 Type R 34F2E266-4BBB-42D4-8F17-C8B6813BEA28
It’s the same exact pipe, just insulated with some seriously good material…
Hard to believe Honda left this pipe exposed, especially with its close proximity to the turbo and downpipe. Suspect track cooling will be improved with this mod.
Honda Civic 10th gen Fatherpain’s 2018 Type R F6BCDC37-4EFE-4327-BF34-77E9B5271536
The OEM water pipe can only be removed if the left or right side is disassembled first.
Honda Civic 10th gen Fatherpain’s 2018 Type R DD2C095D-0E07-468B-8C5A-C214D92DD7E2
The left side has the drive belt, so I chose to leave that alone…
Honda Civic 10th gen Fatherpain’s 2018 Type R 1A4734CB-2C28-4E38-8D12-FFD31A923469
The right side has the thermostat housing, hoses, some electronics and an oil vacuum pump, so went this route.
Centripetal
Boston, MA
2006 RSX Type S, 2017 Civic Type R
The right side has the thermostat housing, hoses, some electronics and an oil vacuum pump, so went with this side.
Thanks again for the great detail and pictures. I've been meaning to ask where do you buy your Dream parts? Thanks for sharing the hard-lagged options. That's the route I would have gone from the get go had I known.
As a side note, it's kind of cool to see the porous nature of the silicone material.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R C272C5AD-72CF-46E8-B302-21CA14AE6F5F
(1) bolt secures the water pipe to the thermostat housing. Remove using a 10mm socket.
Honda Civic 10th gen Fatherpain’s 2018 Type R B04FC67D-7A93-41C2-96B7-C07B6A843854
Bolt removed. There is a black rubber grommet and metal insert that needs to be transferred to the new pipe… I found out the hard way and had to redo part of the install...More on that later.?
Honda Civic 10th gen Fatherpain’s 2018 Type R 46B54BD9-6367-4936-90DD-13856773C642
This is what is needs to come off from the right side in order to free up the water pipe…. is it worth the effort? My OCD says having insulation that can drop 1000F down to 200F is…:doh: but for most, maybe just wrapping the existing OEM water pipe with insulation and a couple hose clamps would be good enough. ?
Honda Civic 10th gen Fatherpain’s 2018 Type R 00D5121E-C0FD-4BFF-AF24-90F1FEBE4055
Separate the radiator hoses from the thermostat housing. There likely will be coolant in the lines so be ready to catch any spills.
Honda Civic 10th gen Fatherpain’s 2018 Type R BCABE082-329F-45A4-A473-BE4D286BA2A1
I Pull the top hose and the lower hose also.
Honda Civic 10th gen Fatherpain’s 2018 Type R 67C281FE-F16D-4575-8A9C-D6CC7A3091C3
Depress and pull this electrical connector.
Honda Civic 10th gen Fatherpain’s 2018 Type R D551B296-54FA-4095-B08B-DF4EA560CD7D
Remove these (2) 10mm bolts to free the electrical harness. **You may notice the oil vacuum pump is already pulled and bagged on the upper right. This photo was taken after the fact for clarity, will cover that portion soon. Doing it this way makes everything easier**
Honda Civic 10th gen Fatherpain’s 2018 Type R 26D39A33-FCFB-484A-99F1-AB234B3E72B5
And disconnect this other harness.
Honda Civic 10th gen Fatherpain’s 2018 Type R 3AD0EA02-11DD-4070-A19F-DF4A74BFE1CE
With everything disconnected, gently lift the electrical harness up and push out of the way. A vacuum hose or (2) may need to be unclipped from their plastic holder.
stariq812
Fairfax, VA
2020 CW FK8
(1) bolt secured the water pipe to the thermostat housing. Remove using a 10mm socket.
Bolt removed. There is a black rubber grommet and metal insert that needs to be transferred to the new pipe… I found out the hard way. More on that later.?
This is what is needs to come off from the right side in order to free up the water pipe…. is it worth the effort? My OCD says it is…:doh: but for most, maybe just wrapping the existing OEM water pipe with insulation and a couple hose clamps would be good enough. ?
Pull this electrical connector.
Kudos to you that's a lot of work, really interested in the temp diff.
fatherpain
fatherpain
Tom
Thanks stariq812. Was a little perplexed on how to go about the install at first…but figured it out looking at diagrams at www.hondapartsnow.com
Unfortunately some of the seals and o-rings are unavailable so will be going back with the same, as they appear to be in good condition. Applying some O-ring lube for good measure. So wish me luck there are no leaks, otherwise I’ll be redoing some work ?
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 677BE6C7-48E1-4B63-A805-D5337F89A752
With the electrical out of the way, here is a good look at what needs to come out to remove the water pipe. Please disregard that it’s already installed, haha.
Honda Civic 10th gen Fatherpain’s 2018 Type R 78083B33-E59A-4DBC-805D-EFA93951016D
Had to pull it back out when I realized I failed to transfer this rubber grommet and insert from the old to the new, until after the new pipe was in. In a perfect world, I’d have done a side by side comparison first, but a couple weeks had past from the time I removed and installed ?
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 06C285B3-DFE6-4865-9B19-C1099576AB59
The oil vacuum pump is secured by (3) bolts. Use a 12mm socket and extension to remove. Do not mess with the torx security bolts, as its not needed.
Honda Civic 10th gen Fatherpain’s 2018 Type R 8F247FB1-9D4B-48C9-A7C1-D64D0291F02E
This step may be specific for the HKS BOV. Regardless, undo any hose that may be here to provide room to access bolts and pull the oil pump.
Honda Civic 10th gen Fatherpain’s 2018 Type R 125053FE-517B-45F3-B097-4EAE8F4D27ED
Carefully pull the oil vacuum pump and swing to the side. I like to place in a plastic bag to keep clean.
Honda Civic 10th gen Fatherpain’s 2018 Type R F0C2EABB-F6BD-46E1-8390-7E97EC8938DD
Be careful to not damage these O-rings, as some are not available for purchase. Notice the slot the pump impeller slides into. Make sure everything lines up when going back together.
Honda Civic 10th gen Fatherpain’s 2018 Type R C2704C9C-DE4E-4662-87D1-6225C6CAE0DD
Disconnect these hoses and remove these (3) bolts holding this pump spacer plate. They also require a 12mm socket.
Honda Civic 10th gen Fatherpain’s 2018 Type R 3C7D9DE1-3790-432F-8A79-F15BEEDDE839
Carefully pull the spacer off.
Honda Civic 10th gen Fatherpain’s 2018 Type R 529696B2-12E9-4F37-A8B0-3327ED9D8769
Note the (2) guide pins. Again, match marks are suggested.
Honda Civic 10th gen Fatherpain’s 2018 Type R AB23140E-0E90-4B21-9881-55063989E383
A look at the o-ring for this piece. I reused it also.
Honda Civic 10th gen Fatherpain’s 2018 Type R B08B11F6-92B9-4152-A50E-DB809EB2C5A8
Believe the beige gunk is Honda bond. It was dry and I did not disturb it. Remove this electrical connector
Honda Civic 10th gen Fatherpain’s 2018 Type R 0753C0A5-409F-4014-9CD9-436A2F45EA27
The purpose for removing the oil vacuum pump and spacer plate is to reach these (3) bolts and (1) nut that hold the thermostat housing in place.
Honda Civic 10th gen Fatherpain’s 2018 Type R D5ECB816-FF82-41A8-9F09-EBDEE8F1052E
The nut is in a horrible spot. Look how far back it is. :drool:
Honda Civic 10th gen Fatherpain’s 2018 Type R 8DD30D3D-EA53-4307-AD3E-8BD336B6E249
To properly reach it, could require removal of the battery and some more piping. Tried pulling the rubber hoses for clearance, then thought it might be impossible to get back on.
Honda Civic 10th gen Fatherpain’s 2018 Type R 0011549D-D18C-4C3D-9AE2-08DA865EC12C
But I'm kind of lazy, so used a pry bar to lift the hose and create space to use a universal wobbulator socket and extension.
Honda Civic 10th gen Fatherpain’s 2018 Type R 608DFE22-FD86-4864-94F8-81B65D7ADE39
Which takes a bit of finesse and patience.
Honda Civic 10th gen Fatherpain’s 2018 Type R 9EA9B2B7-037D-43C5-BE5E-90EFD323BB5C
Strongly suggest backing the nut almost all the way out, but leaving it barely on. That might just be enough to pull the water pipe out. On the initial install I pulled the nut all the way off and it was a pain in the butt to get it to thread back on using the prybar, universal socket and extension, however it can be done. I stuffed a little bit of paper towel inside the socket to keep the nut from falling out while threading back on.
