Fan speed adjustment for Turbo
ilovemycar
CT
2016 Cosmic Blue EX Turbo, 96 Accord EX
Can you change the fan speed using the knob or do you have to use the screen when you want to raise or lower the fan speed? For something that is used so frequently, I don't want to touch the screen every time. The knob works with on the EX and I was hoping the Turbo was the same.
davidgostbo
Texas
Honda Civic Ex-t 2016
I just put it in auto and put temp higher if I want it slower and temp lower if I want fan faster. You can't really feel the temp difference
jmat
2016 Civic EX-L
I just put it in auto and put temp higher if I want it slower and temp lower if I want fan slower. You can't really feel the temp difference
Ive been doing this too. Way easier. I think you meant lower temp for faster fan though haha
ilovemycar
CT
I may be confused by the pictures of the climate controls. Does the EX Turbo right knob say "Push/SYNC" or "Push/ON/OFF"? Honda Civic 10th gen Fan speed adjustment for Turbo 2016-honda-civic-first-drive-sg-33-1280x720 Honda Civic 10th gen Fan speed adjustment for Turbo 20151207_132103
Or does the EX has the "Push/ON/OFF" knob.
corbygray528
Alabama
CR-Z
Turbo says sync, it has dual climate control while I'm guessing the EX just has single setting. The sync function puts the left and the right side in sync and both can be changed with just turning the left knob. You can see in those pictures there are two temp indicators on the top corners while the ex only has one on the left
davidgostbo
Texas
I may be confused by the pictures of the climate controls. Does the EX Turbo right knob say "Push/SYNC" or "Push/ON/OFF"? 2016-honda-civic-first-drive-sg-33-1280x720.jpg 20151207_132103.jpg
My ext is like the top picture, I usually turn sync and auto on, 75-80 is usually a good temp. But when I first start up car when its really hot I just turn the auto knob all the way to low, then adjust as it gets cooler.
ilovemycar
CT
OK, so the only way to change the fan speed from lo to hi on a Turbo is to use the climate screen and touch which setting you want?
The EX fan speed can be controlled using the knob.
davidgostbo
Texas
No turn the auto knob, it adjusts temp as well as fan speed.
jmat
2016 Civic EX-L
you can control the fan speed by using auto mode and adjusting the temp using the drivers side temp control knob, OR use the screen if you want. The passenger side knob on the EX is strictly fan controls only.
