Fact or BS - Dealer said it's normal for CTR to not start after sitting for 6 days
ems657
Michael
Seattle
2018 Subaru STi, 2012 Infiniti G37 (sold)
Hello proud CTR owners,
I learned this from my local dealer today, and this completely blows me away. Is it fact or just some BS?
> I bus to work, and thus, sometimes the car sits on the driveway for 6 straight days.
> In the past, the car would struggle to start (after sitting for 6 days), but still managed to make it. This past Sunday, it finally gave up, and I had to jump it.
> The local dealer told me today that, the newer Honda's have the "technology" that drains the battery even when sitting on the driveway. The computer is still running. Blah blah...
> My other older Honda's would start after sitting for 2-3 weeks. My CTR is 2018 with 12,000 miles. I live in Seattle and right now it's in the 60's (batteries tend to struggle in cold weather).
If this is true, then that means all of us are screwed after parking at the airport for 1 week.
Guys, is this fact or BS?
Thanks,
Michael
Iilac
Spelled with a I not a L for Iilac.
S2000, CTR, TUNDRA, MAXIMA, CX9
Complete BS. There is a parasitic draw somewhere. My car has sat for a week and a half sometimes and it starts right up.
jcp227
Jimmy Mack
Bethlehem, PA
2018 Honda Civic Type R, 1998 Oldsmobile Intrigue (It's even got a rear spoiler)
Complete BS! My car has sat for a little over a month in the winter without starting and fired right up the first try and it was strong.
I think your dealer doesn't want to provide you with a new battery. I would take it to another dealership and see what they say.
ez12a
CA
18 CW Type R
The batteries seem sorta hit and miss with this car. I left my fob in my car overnight once and experienced some strange issues in the week following, as if the battery didnt have enough juice to power the car while it was running. I suspect the fob in the car kept the car "on". It hasnt happened since though and the dealer tested the battery and said it was "OK".
I wouldnt say its normal though. There are times where it seems like it cranks more than usual but it'll start. So far hasnt left me stranded...
WindJunkie
St Augustine, Florida
2021 CTR LE USA-367, 2011 Civic Si (FA5)
Could just be a bad battery. If you got a new battery, and the slow starts continued, that would seem strange. Hopefully you find a new battery solves the problem
98-0425
Nick
Las Vegas
18 Civic Type-R #12307, 98 Integra Type-R #0425, 07 Pilot EX-L, 17 Pilot Elite
BS, mine has sat for weeks and it started right up.
wildbilly32
Kneebraska
05 Porsche C4S 19 CTR #24184 19 Volvo XC40 R
BS! Picked mine up end of February and it sat in the garage until mid-April when it finally stopped snowing. Started right up!
PhilF
Phil
South Central Pennsylvania
2020 CRV EX-L Platinum White Pearl/Ivory, 2020 CRV EX-L Crystal Black Pearl/Grey
Sounds like, as stated in earlier posts, parasitic drain. My Touring Coupe probably has more parasitic drain than most Civics as it has Nav, Sensing and every other memory-hungry electronic widget that Honda has in their arsenal. It sat as long as 3 weeks when I was recovering from surgery, started right up, no issues. Sounds like a lazy dealer, it's most likely a combination of bad battery (have you cleaned the terminals?) and parasitic drain. A battery load test takes 15 min, parasitic draw is easy to measure with a millamp meter, especially one with graphing. Hard to believe the dealer is dancing you around on something this simple, total BS, IMHO.
Gunther
dat ol' Virginee
E46
The amount of accessories installed should have almost no bearing on parasitic drain, especially if the car's designed properly - which I'd imagine it is. Maybe that'll increase the chances of something going wrong, but whatever.
Something weird is going on here - either your battery is shot, you left a light on somewhere, etc. or you've got a genuine parasitic drain issue going on, which I'd find hard to believe on a car this new... but you never know.
You can assess for parasitic drag yourself by getting a multimeter (I have one that's like $4 from HF) and putting it in-line with the battery to see the amperage draw when the car is off. This is easier than it sounds - there are videos on YT on how to do it.
I'm not sure how the Type R is designed, but on my old-ass E46 it takes 16 minutes for the car to go into "sleep" mode. It'll draw like 1 - 2 amps (or something) while the car is doing its typical German fuckery, and then after the time's up it'll automatically go to "sleep" and turn off all interior lights you've left on, headlights, whatever. It'll still draw like <0.05 amps even after it goes to sleep, which is insignificant. Not sure if any of this applies to the Type R/Civics/Hondas - just sharing my experience.
If you've determined you do have a problem, the next step is to determine what's causing it. I saw this fellow on one of the forums use an infrared thermometer on his fuse box to determine which one was warmer than the others to find out what was causing it. Clever SOB.
Nanook
JP
Chester, VA
2009 Accord, 2018 Pilot, 2017 Si, 2018 CTR
BS. My car sits for two weeks a month...every month. It recently sat for nearly six weeks. No issues.
coopermidnight
Brandon
19 FK8
I would love to make a collage of all of the "My dealership told me [insert outlandish thing here]" posts. I wonder how often it's something they truly believe vs something they make up on the spot.
Harlaquin
2017 Type R and a beater ford focus
My local dealer has a guy they pay to just run out the service department screaming " it is your fault you did it, no warrenty" as soon as you pull in parking lot.
