Excessive suspension noise
NoHonor937
dayton, ohio
2017 Lunar silver coupe 1.5T
i just bought the car 3 months ago and only have 1,400 miles on it but every time I go over a speed bump my suspension sounds like it’s moving all over the place. I work for Tenneco automotive and I make shocks so I know a thing or two about squeaky shocks which are due to comtaimination. Even with the radio on I can hear the shocks and springs shifting which started up recently. Is this normal due to cost efficiency or could I have something loose in the suspension? My factory has a speed bump in the lot so I can clearly hear it every day. Should I get it checked out? Not sure if they will fight me for a warranty inspection but I should get it checked for free.
SI_honda_2k17
Can
Honda civic si
Do you have an SI?
Is it happening only on cold weather?
NoHonor937
NoHonor937
dayton, ohio
Do you have an SI?
I guess it could be happening cold weather only. Only noticed it yesterday and today and it’s been 20 degrees out.
SI_honda_2k17
Can
Honda civic si
Ok îm asking that because the SI have issue with noise from the rear suspension in very cold weather (in my case -10d celcius).
In your case it may be different cause
