Hatchi
- Liam
- Feb 26, 2020
- 7
- 125
- 123
- Jacksonville, FL
- 2007 Prius, 2020 BBP CTR
So I was installing the eventuri intake over this weekend.
Main point: Did anyone else struggle a lot with getting the scoop lined up to this hole properly? The scoop is in flush to the metal bracket, though sits a bit to the left (still under the oil tubes though). I tried to adjust it to sit perfectly over the hole in the bottom of the intake and it just wont sit perfectly, it pushes up on the intake even though the scoop is 100% in properly. I roughly followed fatherpain's guidance and was able to get it in, and he also mentioned how to adjust it by loosening the bolt and pushing the scoop leftwards, but that's all while having both intake bolts loosened all the way, and while pulling it off the mount at the bottom. It's just a lot for one person and there's not enough room for a second pair of hands.
Had a ton of struggles (getting the scoop in actually was among the least of my issues). Getting the silicon tube on was a huge pain in the ass, I'd put it on one end (either charge pipe side or intake side) and the other end of the silicon wouldn't go over the tube properly. After some elbow grease and effort I got it in but it took so long for what it was. Luckily nothing broke, I tuned it, I'm getting solid temps, full boost (and then some), and the car overall feels smoother and makes a more desirable noise up front. Very happy with the end result, not so happy with the difficulty of the installation process and the variety that can result.
