Engine Removal without Lift
RBrackett
Ramon
New Orleans, LA
2019 Type R Aegean Blue Metallic
anyone remove the engine without a lift using a hoist? have only seen people drop the engine using a left so didn't know if there was a issue doing so or not ....
the8rotor
Kevin
Texas
'17 Type R
Shouldn't be an issue pulling the engine without a car lift.
the8rotor
Kevin
Texas
'17 Type R
good to know! anything in particular i should watch out for? how did it go for you? what steps did you take, process etc
Why are you removing your engine?
General steps I've always followed no matter the make/model car are the same. These k20c's will be no different.
FlaDiaz22
Jacksonville, Fl
2017 Civic Type R #00418
It was a smooth process, pulled engine and trans together. Clearance was very very small on both sides. Id just unbolt ac condenser and lower it to give you more room. Was able to pick it out without removing crash bar and inter cooler still on.
kshawn
Matthew
Maine
2017 Civic SI
Reviving this thread. When pulling it from the top. Subframe can stay in, correct?
ManitobaSI
Scott
Manitoba, Canada
2017 Civic SI
Yes subframe stays in. Just don’t forget to disconnect the plug for the AC condenser. I stuck a piece of wood under it to sit on whole pulled engine. Have two people to pull to watch either side. More brackets will have to come off as you see what gets in the way. We didn’t remove radiator to take it out but we took out to put it back in. Any questions let me know anytime. iG: @manitobabluesi
