I had no idea. Looking for a calculator to figure out the theoretical increase in compression ratio now. ? Je Piston's how to is a little involved though.His compression ratio will also increase, that should be good for a couple of more ponies.
It won’t be much, a couple of 10ths increase. ECU should be able to compensate even with tune. Just something to watch when you get your motor back together.I had no idea. Looking for a calculator to figure out the theoretical increase in compression ratio now. ? Je Piston's how to is a little involved though.
How to Calculate Engine Compression Ratio and Displacement
I thought compression would only change if you change the rod length, bigger dome on the piston, or taking off material from the head or block. How does the oversized piston increase cr? I’m not familiar with that method.His compression ratio will also increase, that should be good for a couple of more ponies.
of course it won't, unless the cylinder is only honed as far as the rings go.I thought compression would only change if you change the rod length, bigger dome on the piston, or taking off material from the head or block. How does the oversized piston increase cr? I’m not familiar with that method.
I don’t think you would need to go up in octane for .1 increase in cr.of course it won't, unless the cylinder is only honed as far as the rings go.
If this is done just so that the cylinder is not enlarged at all in the dead space (above the cylinder at TDC) then....
Assuming 10.6 is the geometric compression ratio and the displacement volume is 1498 cc, the dead space is 156.04 cc.
If the displacement volume only is now increased to 1519 cc, the new compresion ratio will be 10.73, an increase of 1.27% over the stock. This will require a tiny bit more octane to keep the knock and ignition exactly as before, and then there will be a tiny increase of torque/power, but I expect it will be less than 1.27%, because it seems like the relative power increase should be less than the relative increase of the compression ratio.
I'm sure someone has figured how much increase of max power can be expected from a given increase of the geometric compression ratio.
If the fuel octane is not increased, the ignition would retard a liitle, and the increase in power could be very negligible.
I like using this one, it's been decent so far. And also Honda engine specific!I had no idea. Looking for a calculator to figure out the theoretical increase in compression ratio now. ? Je Piston's how to is a little involved though.
I want to see what those cams do when you port. So far they seem to do nothing with the stock head.I’ve had .25 bigger pistons in my h22 when I refreshed it, it did not do anything. It’s so small a difference. In theory yes the cylinder are wider but it’s very neglible. It’s just to have a smooth cylinder wall surface. On a side note I would like to see more on this topic. Once people start to really bore out these blocks and throw in bigger cams, we’ll start seeing much bigger builds without meth, c16 ect.
Of course you wouldn't. You only would if you wanted to take full advantage of your theoretical power increase of maybe about 1 hp... those with extremely sensitive butts and those who measure acceleration to a hundreth of s second may have a reason...I don’t think you would need to go up in octane for .1 increase in cr.
You have described me to a T. Or to a hundreth of a second, depending on how you look at it.Of course you wouldn't. You only would if you wanted to take full advantage of your theoretical power increase of maybe about 1 hp... those with extremely sensitive butts and those who measure acceleration to a hundreth of s second may have a reason...
I have a set of Saenz rods in as well.not only pistons, it'll be much better with the rods too & you should get 10:3:1 instead of 10:6:1
On na motors, having bigger cams don’t do much unless your increasing the cr, to some degree of course, but I’m not sure about boosted applications. Hopefully people will start venturing in internal work instead of using alternate fuels. Fingers crossed. I’ve asked those at Brian crower and there’s a shop working with them now with somethingI want to see what those cams do when you port. So far they seem to do nothing with the stock head.
