End Links Purchase
DRTHVDR
Justin
NJ
2019 CivicX Hatch
Looking to replace my rear sway bar with the Progress Rear Sway from PRL https://prlmotorsports.com/progress2016hondacivicrearswaybar.aspx
If Im doing the sway bar, I might as well upgrade the end links as well. Will the Type R metal links fit my 2019 Hatch sport? If so, anyone have a link to get them? Or suggest another brand to use?
DRTHVDR
DRTHVDR
Justin
NJ
2019 CivicX Hatch
*EDIT* I found the Whiteline End Links I'll likely go with. Found on ProCar
madchiller
Chad
DFW, TX
2018 Civic Si
I went eibach front and rear sway but the eibach endlinks are out of stock. I picked up the whiteline endlinks but if you want a cheaper route to go you can use the Accord endlinks which are aluminum instead of the plastic Si version.
Another popular low-cost option is the Accord end links.
If you want high performance end links, check out @RV6 Performance.
ManitobaSI
Scott
Manitoba, Canada
2017 Civic SI
Accord end links are metal and are stronger. If you upgrade the bar it makes sense to upgrade the links to help with load transfer if you are really pushing it. Here is a photo of the plastic stock ones beside the accord metal ones with the part number on the bag. They work great.
Honda Civic 10th gen End Links Purchase 32112E02-5307-4C74-9428-F878E0CB7340
Feddy_Ace
Rancho Cucamonga, CA
2019 Civic Hatchback Sport CVT
Co-sign. The Accord ones are super solid and aftermarket ones are overpriced af.
Honda Civic 10th gen End Links Purchase 5D295BB5-37A8-4110-A343-B8EA0EE46C7D
dekoi
Khoi
San Jose, CA
2020 Honda Civic Sedan Sport
which year endlink would i need? 10th gen accord as well? or 9th gen works?
Link if possible please TIA
YankeeSi
jerad
SOCAL
2018 si sedan
Had the whiteline adjustable ones and they clunked like crazy, swapped them out for the accord ones and they've been great. Honda PN:
52320-TLB-A00 x2
ergoodfellow
Erik
Cincinnati, OH
2020 Civic Sport Hatchback 6MT
What do you think about the Eibach front and rear sway bars? How much does it improve the feel of the car?
OsirisPalko
Stephen
Massachusetts
2017 Honda Civic SI
52320-TLB-A00 x2
+1 for whitelines being somewhat disappointing. They are good for adjustability but my set wouldn't "set" and clunked. Ran no sway bar end link until the exchange came in and they are fine but wish I did the accord end links
madchiller
Chad
DFW, TX
2018 Civic Si
It keeps super planted in corners although it can be a little twitchy at high speeds. Definitely takes some getting used to after install.
