Enable subwoofer on premium sound system
Fabio_Bg
Fabio
Italia ??
Civic Sport Plus
Goodmorning everyone
In my Civic Sport plus EU (I'm Italian) with premium sound system does not have a subwoofer as for the US market. (I wonder why....)
In the amplifier obviously the two pins (subw + and subw-) are not wired.
I tried to temporarily connect a sub speaker and the output is not activated.
Anyone know if it is possible to enable the subwoofer on the main unit?
I want to add a subwoofer under the seat and connect it to the amplifier output in order to keep as much of the original system as possible.
Thanks to all in advance.
dstix747
Warner Robins, GA
2020 Civic Hatchback Sport Touring
If your system doesn't include a sub, the channel is not active. For my system, there is a SUBWOOFER adjustment in the audio settings. Unless you have that, there is no message to the OEM AMP telling it to use the output. However, the sub bass is still contained in the output signal to each speaker. Unfortunately, you can't just bypass the Honda amp because all volume and level controls are passed to it as CANBUS messages. IN other words, the head unit knobs and settings don't adjust the head unit line out to the amplifier like it does with non-amplified systems. The messages tell the amplifier to adjust the output signal.
Most people use a signal processor and tap the sub-bass off the left front speaker channel, then feed a powered sub from the signal processor. For a sub-only install, the DSP of choice is typically the Audio Control L2CI.
AudioControl LC2i (Black) 2-channel line output converter for adding amps to your factory system at Crutchfield
You feed the output of the DSP to the power amp of choice for your powered sub. There are a bunch of HOW TO videos on Youtube and threads on how to do it in this site. If you just want the sub bass added to the sound field, and are happy with the "premium" door speakers, then the LC2I is the way to go. You'll still want a powered sub with at least 100-200W to hold it's own against the door speakers.
I have a JL Audio FIX-86 DSP that grabs all OEM amp outputs and converts them to line out levels that feed my JL amplifier. I needed extra power to drive my Alpine door speakers.
Fabio_Bg
Fabio_Bg
Fabio
Italia ??
Civic Sport Plus
La maggior parte delle persone utilizza un processore di segnale e preleva il sub-basso dal canale dell'altoparlante anteriore sinistro, quindi alimenta un subwoofer alimentato dal processore di segnale. Per un'installazione solo secondaria, il DSP di scelta è in genere Audio Control L2CI.
AudioControl LC2i (nero) convertitore di uscita di linea a 2 canali per aggiungere amplificatori al sistema di fabbrica a Crutchfield
Alimenta l'uscita del DSP all'amplificatore di potenza scelto per il tuo subwoofer amplificato. Ci sono un sacco di video HOW TO su Youtube e discussioni su come farlo in questo sito. Se vuoi solo che il subwoofer si aggiunga al campo sonoro e sei soddisfatto degli altoparlanti per porte "premium", allora l'LC2I è la strada da percorrere. Avrai comunque bisogno di un subwoofer amplificato con almeno 100-200 W per resistere agli altoparlanti della porta.
Ho un DSP JL Audio FIX-86 che cattura tutte le uscite dell'amplificatore OEM e le converte in livelli di linea che alimentano il mio amplificatore JL. Avevo bisogno di potenza extra per pilotare i miei altoparlanti per porte Alpine.
[/CITAZIONE]
Hello dstix747
Thanks for the quick and detailed reply.
Unfortunately in the poor eq present in the connect there is no slide for the subwoofer.
I was looking for a way to enable it. But given the lost battle with the dealership and Honda IT for clarification on the 3D Sound module, I think it is utopian to ask to enable the control for the subwoofer.
dstix747
Warner Robins, GA
Hello dstix747
You'll be happier with an aftermarket amp and sub. The Honda sub isn't powered at all, so the output is not amplified any more than one of the door speakers would be (I believe 40W at full volume) and I couldn't even tell it was active. The basic signal wouldn't drive any type of real powered sub without the extra push.
MrWaYne
GER
Honda Civic X 1.5L CVT Sport Plus
this audio signal from the honda amp for the subwoofer output isnt great anyway and barely gives you strong bass. (just something between 30-50hz)
i tapped into the audio signal of the front speakers, which gives you full bass down to 30hz.
dont use the rear speakers, their signal is heavily filtered and has barely bass.
i set my subwoofers frequency range to 30-80hz. it fades out completely at 100hz.
Bob_L
Bob
Atlanta, GA
2021 Boost Blue Civic Type-R
What dstix said. The premium sub is terrible. It had less bass than the oem door speakers in my cheapie Nissan Versa.
ugaexploder
Paul
Atlanta, GA
2019 Civic SI Sedan
i tapped into sub outs…sucks…gonna listen to your advice. thank you
SplinterC3ll
André
portugal
Civic Sport Plus 2017
Hi, im from portugal and have a sport plus too. Have you found a way to activate the woofer in the amplifier ?
My idea is the same as you, maintain the original system and just add a subwoofer.
We (sport plus owners) have a plug in the trunk (12v)that gives 180w, we just need an active woofer in the trunk or underseat and connect to the amplifier in the passenger door. The thing is how to activate those outputs..
If we cannot activate those outputs(sub+ sub-) I read that alpine has an underseat woofer for civic without 3d premium system and its plug and play..someone here knows if we can just add that to replace our amplifier in the door ?
And yes for what i can tell this alpine psu300cvc is active and has an amplifier for 4 channels. If the pins are the same its just plug and play, we might lose 2 channels as we have 6 rear channels (if they are independent).. but even if thats true we gain a woofer at that cost.
And i will bet that this amplifier does not have a bass cut as the geniune. And if this works ones would just buy this just to take out the amp from the woofer and replace the one in the car.
Fabio_Bg
Fabio_Bg
Fabio
Italia ??
Civic Sport Plus
Hi, thanks for your interest in this topic. I've searched everywhere but no one has an idea how to activate the subwoofer output.
Tired of all this, I tried to buy a Joying Radio which is the only one that seems to me to be compatible with the Sport+ system.
Already with the original radio I had replaced the speakers of the 4 doors + the central channel and thanks to the installation of viper4android the sound had improved.
I have replaced the radio for a few months, it works well apart from some lost functions so I'm annoyng the support to fix these bugs.
Of course I've tried hooking up a speaker to the 2 amp outputs but the new unit also doesn't seem to command anything.
I suspect the amp has nothing plugged into those outputs, however I have to ask whoever got the same radio if the subwoofer works.
SplinterC3ll
André
portugal
We need to take out the amplifier on the door and compare the part n with ones that the subw works, and theres a thread here with a detailed picture and schematics with a working one. I will try to find out
From what i read, the amplifier recieves the signal for the 6 channels by a fiber optic or similar cable from the radio/head unit. We need to know were the bass is is cut off. But one of the main reasons must be power.. the rear amplifier is too small, it cannot give the same bass we have on front speakers or it would burn.. thats why rear bass sucks..
Activating sub is possible only with Honda / firmware/ or secret combinations
I recently heard that spanish type-r does have sub. Question, does it have 11speakrs (5front/6rear+Sub )as well or just 2 rears for heat maneagment on the amplifier ?
