Nitroturtle
- Mike
- Feb 3, 2019
- 3
- 354
- 370
- WV
- 2019 PMM CTR, 2006 S2000, 2010 Element EX AWD
Last weekend, I managed to snap a stud while doing a downpipe install. I actually had the downpipe removed without any issues, but had already purchased some rampage studs to install while it was apart. The top stud closest to the engine refused to come out and I ended up snapping it. After much cursing, I hastily removed the turbine housing and eventually took it to a machine shop to have it drilled and retapped.
Last night, I attempted to reinstall the housing and I'm having some problems. Once I had the housing reattached with the v-band, I realized the arm for the wastegate actuator was positioned 2-3mm too short to mount on the wastegate arm on the housing. I also realized, that this positioning is adjustable by threading the metal shroud over the actuator in and out relative to the position of the retaining nut. I can reassemble everything once this is adjusted, but I'm concerned as to why the positioning changed and also concerned that it may now be out of alignment as far as the ECU is concerned.
I'm wondering if I somehow don't have the turbine housing properly seated, though I haven't had much luck trying to gain any spacing there. I've also looked at a local stock CTR and it appears to have the same spacing between the flanges (1-2mm) so I feel somewhat confident that it's assembled correctly.
I haven't been able to find any posts discussing this, except one from a couple years ago that never offered any solution. I also see nothing in the service manual and since the entire turbo assembly is sold as a single unit from Honda I'm thinking the whole assembly is considered unservicable.
I'm really hoping someone more knowledgeable than myself has some insight into this whole process, or direct experience with splitting the turbo and then reassembling.
