Kane666
- Jason
- Jul 18, 2018
- 75
- 994
- 132
- Pennsylvania
- 2018 Civic Sport Touring
- Vehicle Showcase
Ok, so I had d2 springs and I didn't like the way they sat. So I raised my car up higher by getting these sport lines. After the install my rear is bouncy as shit and my rally armor mud guards always scrape on the ground. I did not cut the rear bump stops. I did install rear spring silencers. That is not my primary issue.
My primary issue is the front. My end links went to hell immediately, so we replaced them with moog end links. Wow, that has seemed to solve that problem. My front suspension is still noisy. I have also installed spring silencers in the front. My next thought was ok, we did not pre load the suspension when we put it back in. I had Honda check things out and they dropped the suspension and put it back in properly. They just called me and said they did not find anything wrong and that the noise is still there. They think it is something with the springs. What the hell could the issue be I am at a loss now. And the springs are installed properly. The font, it is right side up so that you can read it the way it is said to be from the company. I did cut the front bump stops. As per the instructions.
