ObsidionXI
- Rafal
- Jul 12, 2021
- 4
- 60
- 9
- Montreal, Quebec, Canada
- 2021 Civic FK7
- #16
Yeah, I might be a little old fashioned as well if it were to come to these types of wheels. I do have quite a few tools in my garage, including a Torque Wrench, so that shouldn't be a problem. I'd probably just settle for hand tightening, and finish off with the wrench once it sits on the ground. Considering aftermarket wheels are a sort of investment in pretty looks, I'd like to keep them pretty as long as possible. It's what I initially though, that is how it should be done, I guess I just like confirmation on many aspects of things I don't usually do, just to be on the safer side."Tuner" lugnuts generally get run down just like any other lugnut. Sometimes they will have a specific maximum torque spec, or require a specific socket, but I've never had an issue with them in my experience.
If you exercise caution not to damage the finish of the wheels or the nuts, an impact can do it... However, you really should pick up a torque wrench to check and set the final torque, regardless of your primary method of running down the fasteners. They aren't expensive, and are much less likely to cause damage to the wheels, lugnuts, or lug bolts. Even a $20 Harbor Freight (or don't you have Princess Auto up there?) torque wrench will do the job.
That said, another good alternative for use with impact guns is a set of torque-limiting extensions, also known as "torque sticks". They're basically socket extensions that are tempered in such a way that they will deflect at predetermined torque loads in order to run down a fastener to a specified torque and (ideally) no further. I don't use them myself, but a friend of mine does, and he hasn't had a wheel come flying off.
I'm old-fashioned (or maybe paranoid?) and I run down my lugnuts manually and torque them down in stages in the appropriate star pattern with a digital torque wrench. I hand-start the nuts and torque them in sequence to 40ftlb, then in sequence again to 60ftlb, and then in sequence once more to the final 80ftlb factory specification. It only adds a few minutes to the overall process, but I know it isn't for everybody.
