Eibach Pro-Plus Springs and fitment
Mckeeversheater
Tyler
Akron, OH
2017 Honda Civic EXT
I’ve seen that a ton of people have the eibach products and I want the eibach pro plus springs and a sway bars kit and I will get camber and struts too. I’ve seen a lot on the si’s fitment but is that the same as the fitment I would need on the 16 ext and if there’s a thread that answered this post it pls . I don’t know much about suspension but I want 18x9 wheels i think what size tire should I get and I don’t want to rub or roll fenders so do I need a certain wheel off set and I’d like to not use spacers
GoldClass
Singapore
Civic Hatchback
Eibach pro-kit can run without chamber and you can wrap with 235/40R18. On the offset, since you want to be on the very safe side, any offset +37 & above will be very safe to avoid any tab mod & pothole after lowered. The +37 is taking the consideration of 9” wide you mentioned but if you change your mind looking at 8.5” or 8”, you will want to look at +40 because 8.5” or 8” is toward square setup compared with 9” poke setup.
Mckeeversheater
Tyler
Akron, OH
Just so I’m understanding you, to get flush tire/wheel fitment if I do the pro kit I don’t need camber and I could use 18x8.5 or 8 with an offset of like +35/+40 wrapped in a 235/40R18 and everything should be safe and look right
GoldClass
Singapore
Civic Hatchback
That’s right. As your is 2016 model, although +35 can give you a flush look on 18x8.5 or 8 but it will rub on the tab due to the square set up. To avoid the tab mod or avoid any rubbing, +40 will be a peace of mind.
Mckeeversheater
Tyler
Akron, OH
You think 45 would look weird cus I’m find some wheels I like at 45
bbeem
Ben
Iowa
I run pro kit with
My wheels have an offset of +44mm. Would even look better if I used 37 or 38mm offset. Springs are Eibach Prokit.
What width wheel? I run 17x9 255/40 +40 on prokit with a little poke. No rub or tab mod. What's prokit-PLUS?
GoldClass
Singapore
Civic Hatchback
+45 is almost close to oem. I would not as it doesn’t really an ‘upgrade’ to me. Try to explore further. For 8” or 8.5”, +38 is the lowest. Below +37 will start to rub on the tab (on pro-kit) once the lowered spring bottom up. +40 is peace of mind because tyre construction differ from brand/model.
Shopping for wheel takes time and patience. For me, if all possible, try to meet these 3; ‘design’, ‘weight’ and ‘fitment’. Even if you pay more for the weight, it is worth it, you can feel the acceleration is immediately lighter and save gas as well.
Mckeeversheater
Tyler
Akron, OH
And a good weight would be
Oskie_01
Joe
Braselton, GA
2017 Civic SI Sedan
A little late to the party, but would 18x8.5 et 38 give enough clearance for a BBK? Still on Eibach pros.
