Eibach Pro Kit: Do I need anything else?
cougtx
Jordan
Seattle
Honda Civic Si
I have a 2020 Civic Si Coupe and have the Eibach Pro Kit lowering springs on the way. Do I need to install anything else along with the pro kit such as a camber kit, spacers, etc? Also, how necessary is an alignment and should it be done after the springs have settled? My car is stock.
Is cutting the bump stop required/recommended? If so, can someone please explain the best/easiest way of doing this.
Thank you in advance!
arpypat
I have a 2020 Civic Si Coupe and have the Eibach Pro Kit lowering springs on the way. Do I need to install anything else along with the pro kit such as a camber kit, spacers, etc? Also, how necessary is an alignment and should it be done after the springs have settled? My car is stock. Thank you in advance!
You should get an alignment right after install.
Rear camber kit probably won't be needed with the Eibach springs. It doesn't go so low that your rear camber alignment would be out of spec. You'll know how far off your rear camber is after you get it aligned.
Sport-injected
Scott
Central Jersey
www.youtube.com
Nope. Just alignment afterwards.
Rustlinjimmies
Meh
Corona CA
2019 Honda Civic Si
can anyone say how much the eibach lowers the car inch wise? I do like the stock height but a little lower wouldnt hurt im considering it
Sport-injected
Scott
Central Jersey
www.youtube.com
1 inch about
Sport-injected
Scott
Central Jersey
www.youtube.com
arpypat
