Economical Exhaust tips
Ryan
Pennsylvania
2017 Honda Civic Touring
Been awhile and don't remember the brand. Got them and returned to Pep Boys. The OEM tips are much more secure and cleaner so I went that direction.
Could you please post some pictures of your car with the OEM tips? Thanks!
89AKurt
Prescott, Arizona
2016 Honda Civic Coupe EX-T, 1969 Chevrolet C-10 pickup
Been awhile since I checked into this thread. I see ads at the bottom for various Amazon sourced tips. The
WHDZ Rear Exhaust Muffler End Tail Pipe Outlet Tips looks bad with the big bolts. But for $37.99....
Timmeh8604
Mary Esther, FL
2017 Civic Hatchback EX
Any non sport hatchback people find some good tips? Thinking of doing a dual tip on each side but can't decide to place them where the stock mufflers exit or at the edge of the centerpiece on the rear bumper on each side so they are a little closer together but not as far as the mufflers are.
shayansiddiqi3
ssiddiqi3
Shayan
Honda Civic 2017 EX-T
@CdnColin, bro tell me if im missing something. Went to canadian tire today and made sure that I got the correct item with the correct part no. However as I got to do it today I ended up having like this. BTW, my civic is an LX model. Thanks in advance.
Hey do you guys know if I install this and also use electric or duct tape to install and make sure it holds firmly; is that a good idea? or tape is not a good way to go? I'm afraid the tips will fall off from my EX-T
saminder
civic
Not a good idea. The duct tape/electric tape will burn/melt and may cause fire hazard. Buy some other tips that fit properly.
Browncoat3000
Red 5 standing by
Todd
Civic Si, Odyssey EX-L
Saminder is correct. Not a good plan.
I used a combination of star washers and lock nuts. No problems with them coming off.
I do notice some rust stains on my “stainless steel “ tips after this winter...
Snoozemore
London
Did my touring today, bought Canadian tire ones, couldn’t be happier with the look - 3” out is just right. I was concerned with previous posts about them falling off, these ones only have set screws, no bracket with teeth to bite onto the pipe. I set them in place and center punched a hole where the bottom screw is, tapped to match thread size and the lower set screw goes all the way through. This way it will never fall off, also cut some of the angle off so the exhaust is better directed out then down.
Honda Civic 10th gen Economical Exhaust tips 4E69F368-EDBA-47AC-9757-43F8E2A2FC66
Honda Civic 10th gen Economical Exhaust tips 0074A2C2-BBE2-4D39-95D5-1071AE5C2885
Honda Civic 10th gen Economical Exhaust tips CA34412C-8F00-4F65-B6C1-AA1F5980F19C
Honda Civic 10th gen Economical Exhaust tips EC559585-637F-4EC9-86CE-00AADC6C41E6
Honda Civic 10th gen Economical Exhaust tips B4FC36BD-AC61-4ABE-A5A2-674FD4A3776D
Honda Civic 10th gen Economical Exhaust tips 93E1DFC1-FD21-48CA-B4E3-A78723376EC5
civicrsturbo
Benjamin
San diego
Honda Civic 10th gen Ex-L
Hey Guys I ended up modifying my muffler tip and diffuser. What do you guys think? I ended up getting Black and red H emblem
Honda Civic 10th gen Economical Exhaust tips F1F02B93-7E70-4F95-8653-AC6CE70A2627
CosmicTouring
Bay Area
2016 Honda Civic Touring, 2014 Honda Civic EX-L Navi
Not bad. How does it look from under and a slightly lower angle? Did you wire up the 4th brake light? How did you get the red trim on the fins by the left and right reflectors?
civicrsturbo
Benjamin
San diego
Thanks,
That red trim is from autozone i just cut it to the shape of the rear reflectors.
I havent wired the 4th brake lights yet.
Honestly it doesnt look bad from a slightly lower angle. You can still kind of see underneath, but its better than the stock diffuser. These diffusers are styled and a bit taller than oem ones if you put it flat side by side
Honda Civic 10th gen Economical Exhaust tips 85D7752E-9485-445C-8609-857B0C3B68E0
HexSosa1
6ix Side GTA
2018 Honda Civic Touring Sedan
Thanks,
This looks really nice gives the rear end a sportier look, I am debating what to do with my 18 Touring sedans rear end. Spoke to a shop a week ago and $120.00 they will let me choose from an erray of tips and weld them on correctly so they dont touch the rear bumper. Sounds a bit pricey but for the job done right I would be willing to pay especially as I see some folks paying that for bolt ons purchased online.
