Dave B
- Dave
- Oct 19, 2019
- 60
- 767
- 468
- Whitby On Canada
- Corvette Z06 (sold) 2020 CW
I have a fair number of years of tracking and racing various cars, almost all of them American V8s, my most recent one being a Corvette C5 Z06 with a stock motor, some alignment and Koni shocks. Took the plunge earlier this year and bought a CW 2020 CTR. Obviously totally different vehicle but decided I needed to try it stock before making any mods etc. Have ended up with 2 days at a track I know well. Lots of 3rd gear corners, and only 2 4th gear corners, top speed about 110 MPH.
https://shannonville.com
So after I got about 1000 miles on the car, I took it to the track for 2 different lapping days in relatively cool temps i.e. around 70. Stock wheels, brakes and factory alignment and here are some of my thoughts.
1) Personally I did not have any overheating issues but rarely ran more than 8 laps of the 2.4 mile track in a row and left the heater on full blast.
2) Stock Continentals are good for a few laps but not a lot more, i.e. they overheat fairly quickly
3) Stock brakes are great but again not for a long time. I run with the double push VSA off in R mode and didn't do the pedal dance. Was not aware of any intrusion by the rear brakes which were no where near as worn as the fronts. I know some folks here think you need to do the pedal dance to get the system completely turned off but that would not be my experience. (Also I believe the pedal dance doesn't work in R mode and I really like the OEM shocks in R mode). Brake feels was excellent but the pedal got mushy after the session was over I suspect due to fluid issues more than pad issues.
4) The limited slip is good but I can still get some wheel spin in hard R hand turns in 3rd gear but easily controllable
5) The car rolls more than I expected but was very stable
6) Seat is very good and shifter is excellent.
So what would I do first? Obviously 18" wheels with real tires and a lot of negative camber for handling, even if the car does roll a fair bit. Also needs better front brake pads (already took Lust's advice and ordered from Paragon) as well as race brake fluid. Personally I am a huge fan of Castrol SRF. Not sure if radiator or oil cooler or both is the right approach but I need to be prepared for hotter days. I think suspension changes other than camber should wait for a bit and I was pleasantly surprised at how well the OEM shocks work in R mode.
So did I like it? You bet. Not quite as fast as the Corvette but way better brakes, shifter, seat and aero than the Corvette and still a very useful car for the street. Given the gains from better and lighter wheel/tire combo and alignment I would not be surprised if the CTR can come very close to the Corvette lap times on this fairly twisty track even while giving up some top speed. Good work Honda !!
