Dyno pull after milltek exhaust install
02SilverSiHB
Annapolis, MD
2019 FK8
Dyno is with no other mods back in Jan 2018. New vids added Jan 2019
318tq and 301hp to the wheels.
Zero drone with this exhaust!
Edit Jan 4 2019, new vids outside the car:
Cold Start:
Short take off:
Ignore the cop at the end...wasn't for me :)
One last vid on the outside:
Edit Jan 2019: Recent vid driving around:
One vid for now
Honda Civic 10th gen Dyno pull after milltek exhaust install 20180119_134145
Another vid
Honda Civic 10th gen Dyno pull after milltek exhaust install 9463_1516762141997
Cold start up sound
MonkeyBoost
Saint Petersburg, FL
2017 Type R #680 CW, 2011 Mazdaspeed 3
Man really wish you did a baseline. :( This is the exact reason i did one. Then i will return to the same dyno after i get exhaust, intake, and intercooler and do a new run.
baldheadracing
Craig
Canada's capital
FK8
"downpipe after the cat" = front pipe (and isn't a downpipe, but isn't included in some "cat-back" systems. I'm not sure why, then again, I'm not sure why aftermarket front pipes don't include the heat shields Honda put on the factory front pipe.)
02SilverSiHB
02SilverSiHB
Annapolis, MD
2019 FK8
You got me confused lol
Which down pipe do you have?
That bottom pic is a cat. As baldracimg said above.
I'm not sure why they call it a downpipe but have seen them called that. I'd call it a front pipe lol.
I don't believe afe comes with it, but this and thermal does
02SilverSiHB
02SilverSiHB
Annapolis, MD
2019 FK8
A/f lines are similar in color, which is which?
I'll check later...but one is from the first run and another is the 2nd run...nothing changed on the car. This is just a dyno with the exhaust on. No before and after...not sure why you'd want to know which is which?
Solis#1730
ScarFace#1730
Miami
Civic hatchback
I know it’s not a before and after dyno run. I wanted to know which line is run#1. Based on th numbers it looks like it ran richer and maybe pulled some timing. If I knew what a/f line was run #1 then maybe that would back up my theory.
wassen
Philip
Sweden
200sx.kicks-ass.net
CTR 2017, Volvo V70
Thanks for the uppload, was there a reason why the pull stopped at around 6300 rpm?
02SilverSiHB
02SilverSiHB
Annapolis, MD
2019 FK8
I'm not sure, but they did mention they couldn't put it in r+ mode because the sensors freak out and through abs and traction lights because the rear wheels aren't moving.
We need hondata bad
Brapdon
Brandon
Portland, OR
2018 CW TYPE R
I wonder why the down/front pipes are flanges and the exhaust is slip joints :hmm:
Says a lot about the "craftsmen" they have making these exhausts.
