DW300c low pressure fuel pump
ayau
Subaru
Has anyone tried the DW300c fuel pump and logged the fuel pump duty cycle data? Per DW, the DW300c provides 62% more flow than the factory pump, but the actual increase at the high pressure fuel pump will be something less. I realize there's a $2,800 kit from, but not everyone is interested in big power nor do they want to spend over $3k+ with labor.
If the DW300c can increase the high pressure side even by a little, that may be worth $180. With a 93 base tune, the fuel pump is already hitting 90% duty cycle.
BrokeCTROwner
Mario
2019 Type R, 1999 K20 Integra
I’ve ran it but I didn’t log anything sadly. My original pump had failed so I decided to upgrade and get the 300c I installed it and I guess the voltage was off or something because the pump wouldn’t send enough fuel making the car cut off at about 4k rpm and sometimes I would stall at idle. I eventually gave up on it and got another oem pump
ayau
Subaru
Was there something faulty on your specific DW300c? I thought these pumps were more or less plug and play.
Also, there's a recall for 17-19 pumps, so I guess I'm not surprised your OEM pump failed.
BrokeCTROwner
Mario
I don’t know if mine was faulty or not I’ll find out when it goes in my integra. And yeah I know about the recall
FK8_K20c1
HONDA The Power of Earth Dreams Technology!
Jonathan
Indiana
FK8 Type R
Giving it more thought. What if the oem fuel pump amperage rating fuse was lower than what the dw300c pump needed and it just needed a fuse change to work properly?
Vincent@27WON
REDEFINE the Aftermarket
Vincent
Las Vegas, NV
www.27won.com
Don't have it in our FK8 but did put it in our SI and it works well.
turbociv910
taylor
wilmington nc
How did it effect the duty cycle?
Seems to be people are upgrading it just so do it. No data has been posted to suggest the stock pump isn't good enough.
I actually have a pressure sensor on my feed and it drops to about 76-78 under WOT and only looses 1 psi by red line.. E70 and efr on 26-27 psi.
gasoline cars should never need a upgraded pump or even ethanol blends on stock turbos.
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
Helped it out quite a bit. We began having intermittent issues with the stock pump. OUr logs would show random drops in pressure which we could trace back to the in-tank pump. We are much more consistent now.
2020CTR
Joshua
San Antonio
2020 civic type R
I’m running fbo with meth And my fuel duty is at 100% , do you think this fuel pump upgrade will help it.
turbociv910
taylor
wilmington nc
see the comment above your post, hes describing your stuation.. and it should help it, keeping a high pressure, or even raising the pressure will let the high pressure pump flow a little more
Learn2turn
Christopher
Rio Rancho NM
Mprice504
Michael
Shreveport, Louisiana
2018 Honda Civic Type R
Did that work? I’m having the same issue and I thinkits the DW300 failing.
