JT Si
Well, after a shit ton of research and a few failed attempts to find a subwoofer that would literally just fit in the coupe rear deck, with the help of @rramrattan I found that the Kicker 44CWCD84 is not only a (tight) drop-in fit in the coupe rear deck, but it also has very good characteristics for open-air/infinite baffle. A generous XMAX of 8.6mm and a total q/qts of 0.767 made it the best possible candidate.
Not to mention it's literally the only subwoofer that will drop into the coupe rear deck with absolutely no modifications.
First, to test and wire it in I soldered a parallel dual voice coil harness into one of the Metra OEM wire adapters. Eureka! The stock amp seems to have enough juice it works.
Due to the absolute lack of clearance between the coupe rear deck and window, even a 90 degree tool to run self tapping screws would not fit. Not to mention I didn't want to permanently modify the rear deck.
Instead, I took my OEM subwoofer (that I busted trying to take the lid off, whoops!) And took off the foam gasket, transferring it to the kicker. Then I removed the lid (again), and evaluated it's use as a mounting adapter.
I took a hacksaw and cut off the lid, so to speak, leaving the circumference with the mounting tabs.
I got out ye olde can of black paint and touched it up to seal the bare metal so it won't rust.
I needed longer screws and spacers to mount this to the top. I happened to have some random spacers and washers that I managed to stack well enough, about 10-10.5mm thick, to get a good mounting pressure to hold the sub in place.
The bolts are M6x1.00, and while I got 30mm they are a little too long. 25mm would be perfect.
I put a 3/4"x1/4" strip of closed cell foam weatherstripping around the bracket to protect the face of the sub mount.
It works!
I then took a bunch of green foam I bought at Joann's and shoved it in around the raised subwoofer mount and in the sheet metal gaps in the rear deck to help seal the front from the rear of the sub.
After a bit more sound testing and sealing up a few more holes in the rear deck, I mounted it for good.
After reinstalling the rear deck and c pillars covers. No rattles! Fantastic.
Looks OEM to me
It's way punchier, much better at deeper bass, and so far no distortion at any volumes I've tested, although I'm sure it's still possible with the OEM amp.
Plenty of gap between my makeshift mount and the rear deck, so no chance of the subwoofer contacting it.
One great benefit of the coupe rear deck being so short is that is is very rigid and has few to no rattles. Even cranking this thing up (limited by the OEM amp, of course) there are absolutely no rattles and no terrible flex of the rear deck. Score one for the coupes.
Enjoy some 480 FPS video showing no discernable flexion in the mount or rear deck.
It works!
Looks OEM to me
