17RGuy
Not sure if anyone else has developed a clicking issue on the seat bottom of their drivers seat, but I did. I noticed the clicking after I had a ton of warranty work done, so I’m assuming some large Marge sat in my car.
Anyways, I pulled the seat out and took it apart. I isolated the clicking to the actual metal cage skeleton. After pushing and pulling on the metal, I found a tack weld had partially come loose. I circled the plug weld in red that had partially popped in the picture below.
This was not weld failure, rather it was not enough weld applied. I should mention I’m out of warranty, which is why I just fixed this myself. Once I found the problem area, I brought the seat out to my garage and welded it with the same er70s6 wire used when it was manufactured.
I have an early build ‘17. Not sure who/if anyone else has this issue. I’m 6’5” 215lbs, and gingerly get in and out of the car, but I’m sure I put different pressures on the seat bottom than a shorter stockier person.
