Drckaglr's stock-ish Mugen equipped FC1 (Check post #55)
drckaglr
drckaglr
Derick
Civic Si
love your build. Beautiful car! I also saw how you plugged your coolant hose with a bolt, neat trick and a learned something new! Why did you swap out the clutch?
Hey, thanks a lot! Yeah that bolt literally saved me a lot from making a mess on my driveway.
Clutch wise, I originally planned on doing a built block + a bigger turbo setup that's why I made the switch to a stronger clutch setup.
drckaglr
drckaglr
Derick
Civic Si
Clutch swap time!!
Me and a couple of buddies (@jedsetperformance on IG) worked on the swap, which I'm glad I did because it definitely is not a job for the faint-hearted. The subframe disassembly and re-installation definitely took most of the time we spent on this! Surprisingly, the stock clutch was still in somewhat good shape after the abuse it took.
Parts installed:
ACT 6 puck clutch with 17lb flywheel
KZCMC
PRL SS braided clutch line
27 Won Race rear engine mount
Whiteline 27mm front sway bar
Whiteline control arms and anti lift kit
Whiteline adjustable ball joints
I definitely recommend doing all these upgrades white swapping out the clutch because everything is easily accessible.
The car feels amazing with the new clutch installed! The engagement point is definitely different than the stock clutch, but the pedal feedback is just a little stiffer. Getting the sweet spot when adjusting the clutch pedal was a pain, but still worked out after multiple adjustments.
The whiteline front suspension upgrades also made a ton of difference! The car feels more planted than it was! But had rubbing issues because the ball joints made the front wheels poke out. I had it aligned to -3.25 degrees of camber, and now it doesn't rub with the current ride height.
I was planning to document every single step of the job, but I got a little too busy with it so here are a couple of photos!
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 8AB51E13-8165-43A3-BBBE-5FD6CD3D28E7
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) FE118FAE-0E0C-4F78-A6CD-C38FD44210AC
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 7FEC69AE-23D9-4CFC-A5D3-B5BDDD6E3D8C
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) B1519557-B0AA-4E0B-85B8-50523E88E67A
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 86EAB781-10E8-438A-AE88-F5A29FA74D51
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 147AFDA8-C249-4578-8C03-9F1120FB609E
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 4575829D-A0FB-4C5F-AD8F-DE56F5739D76
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 7D564F38-00B5-41E6-B3AF-9071F9F465CD
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 4495B36F-C619-4F15-A1BD-114B42CA940E
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) A4713402-5F78-4C3A-8B1D-E5B4619EA27A
drckaglr
drckaglr
Derick
Civic Si
More Mugen goodies!
Front bumper garnish
CF grille garnish
Door handle protector
Start/stop button
I got the front bumper garnish in Crystal Black Pearl because the white, apparently is discontinued. It turned out good IMO but I will get it paint matched hopefully for the next season. Still waiting on a couple of goodies and my build is getting closer to completion!
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 51E236D2-52DE-48E4-8445-B02C0AA96E4E
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 27D89ACC-C1E8-4A08-904D-5A75F28F4198
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 23D0ECBD-7A29-43EA-B43D-7772EA5359E3
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 3A7F78C3-DDCA-4804-BEBC-D8B101D1CDE7
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) AA1CEA38-728E-400B-8E0D-9BB2ED940E77
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 0CB36374-D98C-4635-B496-5FC8F1CE7530
drckaglr
drckaglr
Derick
Civic Si
The Mugen MSR full bucket seat finally arrived!
Paired it with PCI slider seat bracket and I couldn't happier. Build quality is fantastic and has tons of adjustment points.
Overall install was fairly easy. Ordered a 1 watt 2.2 ohm resistor for the airbag code canceller, wrapped the wires in Tesa tape and routed underneath the seat bracket (I tried to make this as clean as possible). For the seat position sensor, I just used Velcro tape to mount it as close to the OEM seat position as possible.
Seat is super comfortable even on long drives. I plan to get a harness bar and appropriate 4/5 point harness for it soon (don't worry about me using the OEM seatbelt for this, it's only temporary :p). Will also get boltser protectors on both sides as they will surely see some wear from getting in and out of it.
Super stoked on this!
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) D9904EFD-7C39-4B02-AB5B-F7D678505B4A
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 5DB175D9-D9C4-4230-906C-AA00B1ED65F2
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) E389EED0-DAF5-407A-9BC7-721045E643E0
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 27B53198-B355-4A20-9928-6B703977E044
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 4ECD6AAF-2024-4B13-B8A3-9505E4F1EE16
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) EB82CAF0-06A8-4010-BF45-011204253A87
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) BE979EF3-7155-4A12-85C6-D200B87C930D
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) F4294C94-6C22-46C4-9502-CD3EE81F2F82
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) D3B5F942-0C46-4F1C-B6C6-5B92C394F40A
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 677CE374-B663-434C-AB99-1C0BB7A3AE17
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 1C6AD98A-66F9-47E5-9740-2C61ADABCC3F
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 8AF28B85-4814-4DA0-B19D-853F7A9E8899
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 60B34571-F931-4926-B2E3-7D726B70D09C
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) DC329E58-CE05-4A44-BF21-55F93A9B9DE3
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 75FF5DF8-0F52-453A-92C1-ED38EA8D3ADD
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) EDAD2746-C604-4570-861A-2F9EED2ECEBC
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 235E2D22-BFA1-4ECC-8F45-070422E5B73F
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 9E656252-926C-4055-87AB-3CC159DBFBCA
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 3ABBEFA0-3C3E-47D6-8F0D-8B826CA68D25
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 3A869379-1397-4A26-93AC-817DA19848F6
Doc_Mello
2019 CBP Si Coupe
All of this is amazing! Does removing airbags in Canada make the car illegal for the street? It does in the US.
drckaglr
drckaglr
Derick
Civic Si
Thanks man!
I believe it is illegal but they're not too strict about it.
drckaglr
drckaglr
Derick
Civic Si
Picked up a set of Enkei NT03M in Special Brilliant Coating in 18x9.5 +40 for a steal!
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 86A888EB-26F1-442A-A6CD-C382E4A37B0A
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 43BDAD2C-4239-47D6-B21B-D18CBDBACA47
Unfortunately they don't clear the 27Won BBK without spacers..
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 399C9200-E7B6-41BA-BD36-EE68A0D4429A
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 69588450-3C1B-42CB-A43B-F479AC1D2248
So I did this for the mean time! This look kinda grew on me instantly!
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) D7F0E93C-A8CF-406A-987F-886C71546DB0
SethNES
Seth
Austin area
2019 Honda Civic Si Coupe
Where do you get all the Mugen parts from? I don't even see a way to order anything from their site unless I'm not seeing something.
drckaglr
drckaglr
Derick
Civic Si
Bought my Mugen parts from King Motorsports and RHDJapan
drckaglr
drckaglr
Derick
Civic Si
Soooo this is an end of an era.... Some unfortunate things happened in the previous days that I didn't expect to happen, but did.
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 10884BBC-2389-4D7D-A181-2E5B80EF56EB
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 39D92CE6-E966-4F40-9A9B-A185ED152961
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 13A15679-33E5-4B5E-A03F-1B10C7A6B7B6
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) E81717E0-A865-4D48-AB84-5A901EC2034C
The car is now back to stock and I no longer own it. Kind of emotional to let go of my pride and joy but I'm sure that it's also gonna put a smile on it's new owner's face. It took 4 days or working 8-10 hours to remove everything. I learned a lot from this build, met a lot of awesome people, and really had a blast over the 2 and a half years of owning it. Might have teared up a little bit while writing this and I hope I don't regret what I've done.
Anyways, here is the new project. A 2021 Civic Type R in Polished Metal Metallic.
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 729B96F5-4728-4803-8746-102E47B59FA2
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) CDDB5024-5E4F-4F5F-B002-C229CC62B7E0
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) BF750CAC-AB5A-4F00-945D-BF2903B0A9F2
Honda Civic 10th gen Drckaglr's stock-ish Mugen equipped FC1 (Check post #55) 5C205157-A61E-4C39-846C-E576D2627CD6
jdm_mike
Acura Canada
20 FK8 CTR & More
Congrats! I too went from the fc1 si to fk8
Did you retain some parts to transfer over? (ie side markers, oil cap, etc)
drckaglr
drckaglr
Derick
Civic Si
Thanks man! First drive was kind of boring since I got used to the Si trying to kill me every time I drive aggressively.
Yes, I will transfer all the parts that fits!
