Err... No. Sure you can get one. Its a $15 part and probably a pretty common thread size. There are no unmachined ferrous parts in the engine that I know of, so a little magnet won't catch squat, You're dealing with an aluminum engine and if you catch any bearing steel she's toast as the steel is usually a backing layer and you will still have bits of copper/lead alloy and aluminum through the whole engine.
I would rather keep my nicely sealing factory drain plug or buy a fumoto quick drain.
It is not. But there is usually a magnet attached inside the transmission you will never see unless it's opened up.Somewhat related: is the factory Type R transmission drain plug magnetic? Sometimes manufacturers put magnetic ones in transmissions from the factory.
Interesting, I've never heard of this. I don't like the idea of not being able to access it to clean it off.It is not. But there is usually a magnet attached inside the transmission you will never see unless it's opened up.
I'm sorry, but Fumoto "quick drain" is an oxymoron.Err... No. Sure you can get one. Its a $15 part and probably a pretty common thread size. There are no unmachined ferrous parts in the engine that I know of, so a little magnet won't catch squat, You're dealing with an aluminum engine and if you catch any bearing steel she's toast as the steel is usually a backing layer and you will still have bits of copper/lead alloy and aluminum through the whole engine.
Well, "quick" refers to your involvement in the process of oil change..... The flow itself with any sort of valve must be slower than the full-bore flow.I'm sorry, but Fumoto "quick drain" is an oxymoron.
If you decide to buy one, the size you need is: M14 x 1.5. The length can be no longer than 18mm (ie M14 x 1.5 x 16 will work).Anyone using oil drain plug with magnet? is it a must buy?
