Does the Si have "Rev Hang"?
PaulME
Paul
MA
2018 civic si coupe, 2017 CRV, 2002 Mercedes E320 wagon, 2001 E320 Wagon, 2002 E320 sedan, 1986 944T, 1972 land Rover
Yes - search is your friend....
repeet
Fort Mill, S.C.
jesus7feasts.fyi
'23 BRZ
Oh gosh yes. Not as bad as my Mazda 6 but, wait yes it is. Looking forward to a lighter flywheel.
BoostedSiCoupe
Cesspool
2019 Civic Si
yes, and like the previous gen it is horrible.
JNRS
NY
2018 Civic Si Coupe
I just traded in my Si for a car that does not have rev hang and YES, the Si has horrible Rev hang when you shift in the upper rpm range. However, you can get use to it if you adjust your technique a bit. It will still be annoying during spirited driving. If you just like to relax and cruise, then it won't really be an issue. Test drive one and see for yourself, but don't make the mistake of overlooking it because it's a shiny new car.
Kenshin737
Ken
Georgetown, TX
2019 Honda Civic Si
I have had best luck using google to search civicx. "site: civicx.com <Search Term>"
Pretty sure it's not really "rev hang", it's rev matching for shifting. I had a WRX and it didn't have "rev hang" or rev matching - you had to be quick on the shift to do that. The fact that the revs stay higher when shifting means a smoother transition between gears, which I find to be a good thing.
Of course, you can always enjoy a good heel-and-toe shift when shifting down, but that's only really reserved for racing. And none of us go racing, now, do we. ;-)
JNRS
NY
2018 Civic Si Coupe
It is not rev matching for shifting. I've had vehicles that had rev matching for shifting and what they do is hold the engine at the correct rpm for the next shift, while you have the clutch pedal depressed. This allows you to take your time and still get a smooth upshift.
minitech
Josh
Winston Salem, NC
2018 Civic SI 4 door
A Hondata protuner can remove it, but overall it still seems to not drop RPM very fast like a NA car (better then stock but still not perfect) some of this is just how the system works i think.
PaulME
Paul
MA
Buzz no it’s not rev matching!! Reev matching means blip the throttle so engine revs faster than current rev for DOWNSHIFTING and would slow engine(cut gas etc) for an upshift. The Honda electronic throttle holds the revs at say 4 or 5k rpm for an inordinate amount of time when you want to shift into the next higher hear - rev hang!
And yes you can adapt to it (although I may look to remove it at some point, but was not planning on playing tuner with a daily driver economy car).
Paul
Luckyarmpit
Garner, NC
2018 VW Golf R, 2003 Wrangler TJ
It's not rev-matching. It's rev hang for sure, and awful/annoying.
JNRS
NY
2018 Civic Si Coupe
Could be worse lol.
ablueSI
SF Bay Area
'18 Civic SI Sedan
Yes. I thought I would despise it - I don't mind it much now, I've grown used to it.
Ideally it would not exist but it is not the worst thing in the world.
Nozomi135
Josh
Moncton, NB. Canada
2017 Honda Civic Si (Modern Silver Metallic)
Definitely does have rev hang, I've gotten used to it however have used KTuner to reduce it, you can also switch from the stock dual mass flywheel to a single mass to give a further reduction!
