civicxxx
- Feb 28, 2016
- 4
- 16
- 11
- Texas
- 2016 Civic Touring - White
Hi Guys,
I made a quick guide on how to sound dampen the trunk lid for the 2016 Civic. This (along with a few other sound deadener additions which I will post guides to later) has really had a positive impact on my stock sound system.
Step 1: Remove the 9 clips that hold the material liner to the metal trunk lid. These clips have two side indentions that let you pop out the middle which will release the clip without damage. The liner should then pop off without issue.
Step 2: Begin strategically adding your sound deadener of choice. I ordered Noico (props to Bworks3) from amazon but you can always go with Dynamat or something else.
Step 3: Reassemble! Those clips you removed earlier should click and lock the liner back into place.
Good luck guys!
Noico that I used
http://www.amazon.com/Noico-Self-adhesive-Deadening-Automotive-Insulation/dp/B00URUIKAK
http://www.amazon.com/Noico-Black-Self-adhesive-Automotive-Insulation/dp/B00PCLPXXQ
-X
- Caution: Be sure to not cover the holes used for clipping the interior piece back on.
- Caution: Be sure that you stay inside the covering area of the fabric for the best look. (Notice on my last picture that I had to push up the bottom edge because I went to low.)
- Caution: Be aware of the weight of the sound deadener you are adding. After 2 or 3 pieces I would close the trunk and reopen it. Keep doing this to ensure that you are not overloading the hinges of the trunk lid.
Good luck guys!
Noico that I used
-X
