MetalKnightCivicHB
DemonRem
- May 23, 2017
- 55
- 974
- 475
- Chicago
- 17 civic hb sport
- Vehicle Showcase
Very nice little mod that can partially convert your hatch engine to an Si.
Si Intake Camshaft cost me around $130 from Honda. Intake side! NOT Exchuast side!
While doing this process, it is also the best way to swap your OEM headstuds to ARP.
(Only if you haven't had a head gasket issue. Only at your own risk!)
Make sure you get your hands on this direction for our civic. I used this as a guide.
https://www.civicx.com/forum/thread...-si-type-r-fc1-fc2-fc3-fc4-fk4-fk7-fk8.46297/
Just want to give thanks to Silent Sausage, and all the other folks involved in putting that together.
Please please read first, research, and be prepared before tackling this procedure.
I am not a mechanic.
Install time: can be done in a day.
Difficulty rating easy 1 to 5 hard: 4
Step 1: Follow this youtube guide to clear the intake camshaft.
From 6:15 to 20:22.
Step 2: Reveal the timing chain tensioner.
ChrisFix has a wonderful video on this. Good thing honda engines are nearly alike.
Watch 10:40 - 11:40
Step 3: Set your engine at Top Dead Center (TDC)!
Again, ChrisFix's detailed video on how to do the TDC. Watch 11:40 - 14:10
Step 4: Release chain tension.
Step 5: Lock the cams in place with a pin.
Step 6: Remove caps that are holding the camshaft.
Using the civicx manual guide, open PDF #5 Engine Mechanical System.
Go to page 105, and follow the loosening sequence.
There are 10 bolts. Here is my quick mock-up guide of order by number.
3 – 7 – 9 - 5 - 1
4 – 8 – 10 - 6 - 2
Step 7: Don't let the timing chain skip!
Important! Before separating the camshaft from the timing chain, I used a bungee cord and hooked it onto the chain allowing tension upward. From what I read, the reason for this so that the timing on the bottom skip. Again, don't let the timing chain skip.
Step 8: Loosening the VTC Actuator bolt.
Very difficult. Will need extra support unless you have some special tool for this.
Step 9: Reinstall VTC Actuator to the Si Intake Camshaft.
VTC gear bolt torque – 85 lbs
Step 10: Placing the new OEM Si intake Camshaft!
I lubed up the camshaft with motor oil.
Step 11:
From 6:15 to 20:22.
Watch 10:40 - 11:40
3 – 7 – 9 - 5 - 1
4 – 8 – 10 - 6 - 2
Step 11:
