DIY: retrofit Hondalink to LX/Sport
yunghro
2017 Honda Civic LX
Can someone do this for me? I’m willing to pay you for the installation.. I’m in the Los Angeles area!! . I’ll buy everything that’s needed before hand thanks!!
Paolo1007
Carson, California
2016 honda civic lx
Hi I’m not good in electronics i have the 2018 head unit from type-r that i want to install on my LX I bought the gps and the wire to the tablet but i cant figure out the wiring i need to power the unit please help me im from socal
yunghro
2017 Honda Civic LX
Does anyone have any links on where I can buy the 5 pin and 16 pin connectors ?
Wisch
Matt
SLC, UT
2018 Civic LX Hatchback
yunghro
2017 Honda Civic LX
Is it possible to just put in the dupont connectors inside the unit without buying these socket housings?
edit: I did this for the 5 pin... is this ok?
Honda Civic 10th gen DIY: retrofit Hondalink to LX/Sport 9C5FB0E9-BA61-4F06-9BFB-53BDECC4BDDA
Edit2: I couldn’t get the unit to power on... my old unit still powers on perfectly
Ender
Kevin
California, USA
2016 Civic LX Sedan
Real quick, does anyone know the difference between the 39101-TGG-A21 headunit and the 39101-TEG-A81 headunit? They should both be compatible with the 4button+knob LG tablet.
kotarou
Brazil
Honda FC2 - FFV
Does anyone know if it's possible to just swap the screen from a unit without knob to one with it?
kotarou
Brazil
Honda FC2 - FFV
Yeah, but I don't know if my idea is crazy. I would like to swap just the tabet display and keep the unit. I'm not sure if this is possible.
MrRicer
Ryan
2018 Honda Civic Hatchback LX
So is this possible for someone who has 0 experience whatsoever with this type of stuff? Not as far as removing the interior pieces and etc.
But changing the connectors and stuff? I want to give this a go, but seems like it takes an experienced and knowledgeable person to tackle this
In SoCal and willing to pay somebody to do this lol
Fred
palmdale ca
2017 Honda Civic LX
I haven’t got my fm tuner yet but I did figure out the wiring for the back up camera. So there is a wire loom behind the kick panel in the driver side footwell and there is a light green/turquoise wire for the reverse lights and if you splice into that you can run the wire up to the head unit
This is the wire you need to splice into, be careful in my car there were two that were the same color but the first one I tried wasn’t for the back up camera.
I used a blue remote wire for an amplifier I used one of those blue things to splice into the reverse light wire.
Ran the blue wire up and behind the head unit
This is the wire harness that you will run your wire to
Shove the reverse wire in this slot number 15
Wire shoved in slot 15 and taped together so it stays put for now
It works lol
I successfully retrofitted an EX radio to my LX, I tapped on the green reverse lights wire and blew the meter fused attached to it, then cluster went blank. I am leaving the rear cam disconnected for now till I find a better solution. New cars do not like any voltage drops or overloads. Any other solution pls post.
DGriffin
2017 Honda Civic LX
Hi, all. Did anyone ever figure out how to get the reverse camera to work automatically without splicing into that wire near the peddles?
The original head unit accomplished this using one of the wires in the OEM harness, right? Would it be possible to feed the signal from that wire into the new unit?
ColKaizer
Los
Colombia
Honda 2019 Hatchback sport
Here are photos of the completed swap in my 2018 LX hatchback:
FM/HD Radio:
SiriusXM:
Working vehicle integration:
Android Auto:
Reverse Camera:
Thanks to everyone that paved the way on this!
Next mod, variable wipers :thumbsup:
This is amazing bro. Can you do a before and after?
astrazinca
U.S
CIVIC LX SPORT
hi
just want to know where is the best location that i can fix my AM/FM module because after installation and putt near dashboard very noisy while on
circuit.heart
Brian
San Jose, CA
'18 Sport (Si converted), '94 525i x2
hi
I glued mine to what feels like an A/C vent underneath the passenger side of the dashboard. Locking down all the wires helps big time to quell vibrations since you're unlikely to be making a factory style harness when doing this mod.
I finished mine this morning, including the reverse camera trigger.
If I can add one thing, anyone attempting to do this mod should avoid using wire taps. Unstable voltage on the + line was preventing my screen from turning on. As soon as I wrapped and soldered the wires in, everything worked perfectly.
