16 - https://www.mouser.com/ProductDetai...GFUTAoTh6Yw==&countrycode=US¤cycode=USDDoes anyone have any links on where I can buy the 5 pin and 16 pin connectors ?
Is it possible to just put in the dupont connectors inside the unit without buying these socket housings?16 - https://www.mouser.com/ProductDetail/jae-electronics/mx34016sf1/?qs=P1rOgYsovGAGFUTAoTh6Yw==&countrycode=US¤cycode=USD
5 - https://www.mouser.com/ProductDetail/jae-electronics/mx34005sf1/?qs=P1rOgYsovGCVdqgCSLR1og==&countrycode=US¤cycode=USD
Pins to go in those connectors - https://www.mouser.com/ProductDetail/jae-electronics/m34s75c4f3/?qs=cjOFguiotuIyjXQGAsCwAw==&countrycode=US¤cycode=USD
I successfully retrofitted an EX radio to my LX, I tapped on the green reverse lights wire and blew the meter fused attached to it, then cluster went blank. I am leaving the rear cam disconnected for now till I find a better solution. New cars do not like any voltage drops or overloads. Any other solution pls post.I haven’t got my fm tuner yet but I did figure out the wiring for the back up camera. So there is a wire loom behind the kick panel in the driver side footwell and there is a light green/turquoise wire for the reverse lights and if you splice into that you can run the wire up to the head unit
This is the wire you need to splice into, be careful in my car there were two that were the same color but the first one I tried wasn’t for the back up camera.
I used a blue remote wire for an amplifier I used one of those blue things to splice into the reverse light wire.
Ran the blue wire up and behind the head unit
This is the wire harness that you will run your wire to
Shove the reverse wire in this slot number 15
Wire shoved in slot 15 and taped together so it stays put for now
It works lol
This is amazing bro. Can you do a before and after?Here are photos of the completed swap in my 2018 LX hatchback:
FM/HD Radio:
SiriusXM:
Working vehicle integration:
Android Auto:
Reverse Camera:
Thanks to everyone that paved the way on this!
Next mod, variable wipers
I glued mine to what feels like an A/C vent underneath the passenger side of the dashboard. Locking down all the wires helps big time to quell vibrations since you're unlikely to be making a factory style harness when doing this mod.hi
just want to know where is the best location that i can fix my AM/FM module because after installation and putt near dashboard very noisy while on
