casper
- Michael
- May 18, 2021
- 23
- 536
- 508
- NC
- 2021 Civic Sport Hatchback (6MT)
- Build Thread
- Link
Being an engineer / data scientist by profession, I found it very helpful for myself to make a "standard operating procedure" that I could print off and check off the steps as I do an oil change. I realize oil changes are probably trivial for most of you, but I also realize the severity of damage that can be caused if you screw up... And after all, isn't the main point of doing your own oil change to avoid putting your Civic's life in the hand of a dealership or quick lube shop? It might be marginally cheaper, and definitely will take you longer, but I think it's worth it to know that some trainee isn't going to ruin your beloved.
Anyway, attached is the SOP as a PDF and a Word doc. Feel free to print and use for your own purposes.
Since I was using ramps, and that makes the whole "being on level ground part of checking the oil" somewhat confusing, I figured the way I have documented here is the most efficient way to go through the steps that were listed in the manual. I added a few other tips and tricks that I myself came across that I figured would occur commonly enough. I also actually performed multiple oil changes with this SOP and have already added a few rounds of revisions following it.
Lastly, if anyone has any suggestions to make this better, please comment! I'm hoping someone here will know a better / more efficient way to do something, or has any additional troubleshooting tips
EDIT: last update made November 23, 2023
