MT_FK7
So this was done on an lx hatchback, I believe most of the other models the map light turns on with the dome light anyway - but I wanted to put this up to share if anyone wants to make this simple mod. You basically are tapping into the controlled ground from the dome light and adding it to the unused pin of the map light module.
Start by removing the map light module and the dome light.
Fish a wire from the dome light to the map light hole above the headliner.
The controlled ground on the dome light (connected to ground when door is open) is the green/teal colored wire.
You can splice this wire but I preferred to use a spade connector and tap into where the bulb mounts. The advantage by using the spade connector is the off switch function is preserved so if you don't want the map lights on with the door open switching the dome light to off will kill all the lights. BE CAREFUL WITH THE SPADE CONNECTOR THE BULB HOUSING BREAKS EASILLY!!!
On the map light side now strip a bit of wire back from the extra wire you ran from the dome housing. Shove this wire down into the empty pin of the map light connector.
Secure with some zip ties and - check the function before putting it all back together and you should be good to go!
