DIY - EDM tail lights (with rear fog light)
17CivicTypeR_Brian
York PA USA
For now, I'll mostly be dumping photos of the process, or notes of findings, until I can get to the end and summarize it.
Parts list-
Stalk switch - 35255-TLA-R11
Fuse tap-
on your own!
Relay-
5amp would be plenty being that this is a sub-2W LED light.
20ga wire
18ga wire
This looks like it's the connector in case you want/need it-
04321-SJC-305 https://www.parts-honda.uk/honda-cars/assignment_spare_parts/04321SJC305
04320-SJC-A00 https://www.parts-honda.uk/honda-cars/assignment_spare_parts/04320SJCA00 - sub cord grey - might just be wire.
04323-SP0-A01 https://www.parts-honda.uk/honda-cars/assignment_spare_parts/04323SP0A01 - Joint, Terminal yellow.(this should be the 'harness pin' that needs to be inserted in the USDM connector-)
Watch for updates-
If anyone (Honda employees) or anyone else wants to comment or help in any way without registering on this site to do so, please feel free to email me at [email protected]. I have no problem maintaining source anonymity as needed.
17CivicTypeR_Brian
York PA USA
  • #2
This is the installed tail light. The fog function is not yet enabled-
17CivicTypeR_Brian
York PA USA
  • #3
October 13 2017 update-
I did some 'bench' testing and was able to successfully get the the rear fog light to illuminate on the US driver side. I suspect only my driver side will light up, but I will test it once again-
The top pin seems to be ground and the middle pin is the + for the fog light.
I have the remaining components on order - I'll do some photos once I get those parts in-
I'll have a picture of the bench test when I get to some WiFi!
17CivicTypeR_Brian
York PA USA
  • #4
Bench test. This is the LHD driver side assembly!
17CivicTypeR_Brian
York PA USA
  • #9
17CivicTypeR_Brian
York PA USA
  • #10
17CivicTypeR_Brian
York PA USA
  • #12
What's happening here?
I'm just throwing up pictures of everything. I never know if some angle or something might be just what someone is looking for!
17CivicTypeR_Brian
York PA USA
  • #14
Did you end up buying a turn signal stalk with the rear fog light toggle?
Yes I have it here. I was actually just about to take some pictures of it and the connection point at the rear to see how it looks. Hoping I just need to add a pin to the existing connector.
17CivicTypeR_Brian
York PA USA
  • #15
edit - these pics should have been in a different thread
