Design
- Sep 28, 2015
- 28
- 3,329
- 2,903
- Southern California
- 09 MS3, 17 ABM Si Sedan
This is an easy how-to and one I was going to skip. But inevitably there will be someone who will try and replace the entire to slider vs. the cover (or break a tab by pulling the covers the wrong way).
Time: 5-10 minutes
Tool: Phillips screwdriver (and maybe an interior plastic separator for the three covers.)
Parts: 3 leather components sold by Honda for around $90.
Parts and the couple steps below:
Step 1: Remove the left and right covers. Apply firm, upward pressure on one end, working your way to the other side until all four tabs are released from each side.
Avoid sideways pressure or you will break the alignment tabs.
Step 2: Remove the cover on the old and new slider assemblies. (Do not be that guy and remove the entire center console lol.)
There are two screws and four tabs that hold the top cover in place.
Step 3: Install is in reverse. Press in the left/right covers and top cover. Replace the two screws on the underside of the slider assembly for the top cover.
You're done! No more scratchy arms or unsightly worn fabric.
Time: 5-10 minutes
- Left console cover: 83416-TXM-A11ZA $23
- Right console cover: 83411-TXM-A11ZA $23
- Center console slider assembly: 83441-TXM-A01ZA $45
- Remove the two screws.
- Lift the cover from the assembly, starting at the front near the screw holes.
