luthacris
@Luthacris
- Chris
- Oct 14, 2018
- 22
- 26
- Dove Canyon
- 2018 CW CTR #19009
- Vehicle Showcase
Here are the instructions I found on a CTR FB page.Thank you
Is it the plug or wires that are located right under the h11 bulb? Did you just T- clamp?
Step 1: Remove the bumper. Likely the best video out there. Thanks to some friends for sharing. (https:// youtu.be/V-KI2seSiMQ)
Step 2: Run Diode Dynamic harness through the hole in the fender into the bay.
Step 3: Cut the DRL harness sleeve to expose the
DRL relay circuit wire, it's the purple wire. Thanks Corie Burk and Jason Lee for confirming this. Be careful to not cut through the wire like I did on the driver's side ?
Step 4: Install the line tap. Thanks to Jason Jason Lee Lee for the suggestion on the Posi-tap. They're smaller which makes working in this tight spot easy.
Check out a video of how they work: https://youtu.be/ 5vOSV1LVMo4
Step 5: Protect the wire tap with your tape of choice.
Clean up and zip tie the excess harness along with the OEM fog light harness.
Repeat Step 2-5 on the driver's side.
Step 6: Reinstall the bumper.
