Brakes88
- Aaron
- Jan 15, 2018
- 30
- 548
- 332
- Edmonton alberta
- 2019 TYP SI
- Vehicle Showcase
I just got home after going out with the GF to test drive a 2020 SI, and i can say that the HFP suspension handles small bumps and seams in the pavement much better. The 2020 is the same as earlier years. I live in edmonton alberta and the roads get rough here in the winter and after the spring melt so the HFP is a huge win for me as it feels much smoother over bumps and ruts. If you want a stiff ride that is track ready I think aftermarket coil overs and or stiff springs one or replacing oem would be the best option. If you have rough roads and find the si to feel a bit rough and want a smoother daily driver the HFP is probably for you. And if you factor it in installed before delivery it should be covered by the factory warranty. Which is most likely better backing then any aftermarket option.One more question that I have is the difference between the 2020 Si's suspension (which is listed as active dampening) and the HFP option. I would highly doubt that I would go for the HFP (given the price an other options out there), but wanted to see if anyone had experience with it or thoughts about it compared to the stock 2020 Si.
Thanks again!
