NHCivicGuy
Was always secretly missing the heated seats that I’ve always had in my previously vehicles, including my Si. Already installed a Fortin remote starter last year, so I can remote start it from anywhere using my smartphone. Decided today was the day I was finally going to install an aftermarket kit into my R.
Crimestopper (also owns Fortin IIRC), which makes some electronics and remote starter stuff for vehicles, has a quality kit. It wasn’t perfect for our seats with the contours and channels we have, but it worked out well enough for me. I’m very happy with how it turned out. My butt, and my co-pilot, is toasty warm .
Tools used:
5 Pack 12V Car Add-a-Circuit Fuse TAP Adapter Mini ATM APM Blade Fuse Holder https://a.co/d/9WGOn9X
TOOLEAGUE 4 Pcs Snap Ring Pliers Set, Circlip Pliers, 9 inches Internal/External Heavy Duty for Ring Remover Retaining Straight Bent Lock Ring Pliers Set https://a.co/d/5sSluub
Hog Ring Pliers Curved Open Spring https://a.co/d/hL78cWx
Parts:
Crimestopper HSK-150 Heated Seat Kit https://www.ebay.com/itm/2343655289...VUhwTBORuC&var=&widget_ver=artemis&media=COPY
Honda Genuine 04810-SB3-000 Trim Fastener (30 Pieces) C-Clip Set https://a.co/d/hqxrTHE
14 gauge wire to extended the provided heated seat wiring, solder iron, solder, shrink tubing, and a wire connector for grounding the wires to a ground point.
I soldered both grounds together and used the nut of the dash frame near steering wheel. The positive taps I plugged into the Rear Window and Aircon, which only power when vehicle is on.
Tools used:
Parts:
