Did a rear rotor swap, Electronic Brake Problem -- Dealership says REPLACE ENTIRE CALIPER???
Ars3nd
Andres
Dallas, TX
'17 Civic Type R
Hey there, I'm running into an issue that I'm guessing has to do with the wire harness attached to the e-brake actuator, but I'm not entirely sure what more I can do, I've attempted to re-seat it, and just in case I swapped the position of where the wires are but it remains throwing that code and the brake is not functioning when I apply the parking brake. It functions on the passenger rear, but not the driver rear.
Can anyone give me any insight on this? I tried to take it to the dealership and they hit me with a quote of $1500 to replace both the calipers and bleed the system. They also had the balls to tell me about how they don't understand how anyone could swap the brakes on their own without the HDS computer, as it's absolutely necessary and will break the car if you don't. So Honda now monopolizes brake jobs too? I refuse to believe that...
Anyway! Here are some pics of what's coming up on my Dash, and they were willing to tell me the Code when I left the dealership --> C1110 - 13 ; "Left rear electronic parking brake actuator circuit open"
Honda Civic 10th gen Did a rear rotor swap, Electronic Brake Problem -- Dealership says REPLACE ENTIRE CALIPER??? 7J6Od0O
Honda Civic 10th gen Did a rear rotor swap, Electronic Brake Problem -- Dealership says REPLACE ENTIRE CALIPER??? b2JdYO
Honda Civic 10th gen Did a rear rotor swap, Electronic Brake Problem -- Dealership says REPLACE ENTIRE CALIPER??? yWwhz84
Honda Civic 10th gen Did a rear rotor swap, Electronic Brake Problem -- Dealership says REPLACE ENTIRE CALIPER??? aqTy49c
Honda Civic 10th gen Did a rear rotor swap, Electronic Brake Problem -- Dealership says REPLACE ENTIRE CALIPER??? DNELoqC
Type Rocket
Andy
Atlanta
2017 CBP FK8 #2650
I also did a rear rotor and pad swap but did not run into this, so access to whatever computer they mentioned is NOT mandatory. I think you probably kinked a wire or might have inadvertently pulled something loose on yours. I would compare left and right sides with attention to details to try to determine where the problem lies. Worst case you may have to replace a shorted wire harness or possibly the actuator on the left side. That repair quote from the dealer is BS.
Honda Civic 10th gen Did a rear rotor swap, Electronic Brake Problem -- Dealership says REPLACE ENTIRE CALIPER??? 15518237394054206305738435388857
Hmac111
Nova Scotia
Honda civic, Mitsubishi Mirage
I know this is 2 months later so you've likely resolved your problem but I had a similar issue, finally had to take it into dealership and turned out to be a broken harness.... was told by mechanic that theyre ridiculously easy to break if not super careful, they've broken many themselves when honda changed to the electronic e brake....thankfully its apparently 30ish bucks for the part and a half hour of labour.
Davgto25
David
2016 civic ext and 2019 Rdx aspec
Did you figure out your problem I'm running into the same problem my self . I did a rear brake pad exchange and after resulted with the dash board codes . The dealer told me I fuck up the driver rear caliper ? Any advice of what you did with yours ? I actually exchange the whole caliper already but still with the codes ?
frtorres87
Frank
New Jersey
2017 Honda Civic Type R
Where did you purchase those rear rotors?
ez12a
CA
18 CW Type R
the post right above yours says to replace a $30 harness for the ebrake. Next logical step for you since you've already replaced the caliper.
18TypeR-13922
ADM
Philadelphia
2018 CBP CTR, 2022 MDX A-Spec, 2015 Accord EXL
Can someone post a picture of the wiring harness and also the part number for those of us who will be changing pads in the near future?
garym0510
Gary
Northern KY
2017 Civic EX with Sensing
Running into the same exact problem. I just recieved the obd2 computer to try to do the put brake into maintenance mode but it said the exact thing yours does. Open circuit. Driver side. Did you figure out the fix to this. I've checked my harnesses all are attached and pretty sure i didnt break or pull any but I will replace it rather than pay 1500 dollars.
Honda Civic 10th gen Did a rear rotor swap, Electronic Brake Problem -- Dealership says REPLACE ENTIRE CALIPER??? Screenshot_20200606-184025_Autel MaxiAP200
Caestus
Jeremiah
Miami Florida
19 Civic Type R
This is a very real problem if you do not service your brakes in maintenance mode. SOME people get lucky, and others do not. It usually results in an entire caliper replacement.
It is wildly encouraged to service your rear brake pads in maintenance mode.
FK8Guy
VA
CTR FK8
how do you enable maintenance mode?
Caestus
Jeremiah
Miami Florida
19 Civic Type R
FK8Guy
VA
CTR FK8
There is an OBD2 scanner sold on Amazon for 60 bucks. If I am not mistaken it is an Autel 2000 (I have one) The model I wrote here may be off a bit..... However, I can post the correct one later. This OBD2 scanner puts the rear parking brakes into maintenance mode.
Edit:
This is what I purchased and works like a charm!
https://www.amazon.com/Autel-AP200-Bluetooth-Professional-Automotive/dp/B07QD4GZW4
Thanks .. what is the purpose of maintenance mode? Cut the electricity in the harness not to burn out something?
kimtyson
Kim
York, Pa
2020 Blue Civic Si Coupe
OP: that dealer is obviously not interested in you, your safety, or even your issue. You have a very serious (potentially) brake issue and they want to get paid to replace your tires and cabin air filter. Take it to another dealer that isn't so motivated to steal your money and is more motivated to resolve your issue in a fair way.
Caestus
Jeremiah
Miami Florida
19 Civic Type R
It’s to retract the piston inside and then properly engage the piston against the brake pad when the job is completed (must be taken out of maintenance mode only after the brake pads are installed and the caliper is completely bolted on)
fatherpain
Tom
Some rear brake pad madness and recovery, when I changed mine out Here
