JT Si
The Honda service manual has a written procedure to do this manually without an HDS or any form of scanner. You just follow the steps for engaging/disengaging the brake in order, and manually retract the piston with a tool.It’s to retract the piston inside and then properly engage the piston against the brake pad when the job is completed (must be taken out of maintenance mode only after the brake pads are installed and the caliper is completely bolted on)
If it wasn't an accepted and successful method, why would Honda write it in the service manual?
